weird bogging
Old May 8, 2011 | 11:29 PM
efkilla's Avatar
Default weird bogging
hey honda tech my integra bogs when i give it gas but then slowly piks up any one have any ideas y its a 2000 ls thank you
Old May 8, 2011 | 11:32 PM
el crapitan's Avatar
Default Re: weird bogging
have you checked for codes?
Old May 9, 2011 | 12:39 AM
efkilla's Avatar
it dosnt trow codes its starts idles but when i give it gas it bogs i change the coil its getting gas
Old May 9, 2011 | 01:17 AM
check for codes regardless. the cel may not have illuminated, but a code may still be stored
Old May 9, 2011 | 05:44 AM
Bowl_of_Rice's Avatar
just do the basic tune up NGK spark plugs and wires new oem cap and rotor. use an injector cleaner lucas is pretty good
Old May 9, 2011 | 07:00 PM
efkilla's Avatar
change the fuel pump ignitor coil today still same prob
Old May 9, 2011 | 08:35 PM
did you check for codes yet?
it's a 2000. i wouldn't be surprised if at least one was tripped.
if none are present, you can try installing a fuel pressure gauge and driving it with the gauge in visible spot. see what happens to fuel pressure when it bogs. at least this way you can get an idea of what's going on rather than changing parts futily
Old May 9, 2011 | 08:45 PM
efkilla's Avatar
ima try different injectors and fuel gauge
Old May 9, 2011 | 09:00 PM
just try checking the codes. it takes a fraction of the effort of changing those parts and doesn't cost anything. it will also point you in the direction to solving your problem. utilize the system that was put in place for this very reason
Old May 9, 2011 | 09:02 PM
efkilla's Avatar
how do i check codes if there is no check engine light
Old May 9, 2011 | 09:30 PM
i'm not from the states, but i think autozone does free scans.
or else pull the passenger kick panel cover. locate the 2 wire connector. jump it with a paperclip. turn the key to the II position. the cel will flash in correspondence with the code(s)
here's a more detailed write up on it. it's for 1994, but should work the same
http://www.modifiedlife.com/how-to-r...acura-integra/
Old May 10, 2011 | 12:21 AM
efkilla's Avatar
oh i know how to do that way i thought there was a different way of doing i messed with the dizzy and it fixed the probe alil
Old May 10, 2011 | 11:14 PM
efkilla's Avatar
yessss i finnaly figured it out it seems that the intake cam jumped a tooth when i was adjusting the tensioner realigned and its running like a champ
Hypochondriac
Mar 28, 2011 02:28 AM
Naiyasin
Mar 21, 2011 11:51 AM
just_hatched
12
Aug 12, 2010 02:30 PM
johnny_bighood
19
Aug 1, 2009 04:21 PM
