water pump tools??
Old Jan 31, 2007 | 05:23 PM
whiteboy03si's Avatar
Default water pump tools??
I am about to get a DA and it is about an hour from my house. The only problem it has is a bad water pump. What tools do I need to change it?? 92' Interga LS
Old Jan 31, 2007 | 05:28 PM
doood's Avatar
been there done that
Default Re: water pump tools?? (whiteboy03si)
basic hand tools
Old Jan 31, 2007 | 05:36 PM
Default Re: water pump tools?? (doood)
would i be all good with a socket set, some channel locks and a set of open ended wrenches? Or do i need anything else.
Old Jan 31, 2007 | 08:23 PM
god.loves.ugly
Guest
Posts: n/a
12 mm 10 mm 14mm deep. ratchet, extensions and some honda bond
Old Jan 31, 2007 | 08:43 PM
youdontknowmeeither's Avatar
Default Re: water pump tools?? (god.loves.ugly)
don't forget the new timing belt and tensioner you should probably put on right away..
Old Jan 31, 2007 | 09:00 PM
Sam92Teg's Avatar
Good luck removing your crank pulley bolt with that tool list.
Mr_Moos
Jun 24, 2007 10:04 PM
Shaguar47
May 26, 2007 09:40 AM
91tegrals
Jan 16, 2004 04:13 PM
parasonic
Jun 16, 2003 06:26 PM
