Water pump question
Old Mar 26, 2003 | 07:49 PM
monicle's Avatar
Default Water pump question
I thought I would post this in ehre since more of you will be familiar with the application.:::
Ok heres a picture of the stock water pump from a jdm b18c.
And heres the Bosch water pump I got from pep boys.
Notice the 2 alignment "pegs" arent on the new one. All of the other dimensions are identical as far as hole locations and whatnot. slight variations but nothing that would cause fitment problems. Those alignment pin things concern me though. Did I perhaps get the wrong one or is it not a big deal?
Old Mar 26, 2003 | 07:53 PM
Diego Boost's Avatar
Default Re: Water pump question (monicle)
I would be leary of running that without the pegs. Double check to make sure they gave you the right part, if so then I would look into getting some fittings to put in place of where they are missing as compaired to the stock unit. That's just my .02
Old Mar 26, 2003 | 07:57 PM
monicle's Avatar
Default Re: Water pump question (Diego Boost)
yeah couldnt hurt to double check with them. Any one here replaced theirs before and had or didnt have the pegs on the replacement?
Old Mar 26, 2003 | 08:01 PM
tilt's Avatar
I actually forgot to put on the dowel pins on my water pump for my crx. It's working fine so far.
Old Mar 26, 2003 | 08:05 PM
rathead's Avatar
Default Re: Water pump question (tilt)
i think only the jdm waterpumps had the dowel pins, and they dont come out. every waterpump i have seen did not have those unless it was off a jdm engine.
i wound not worry about them, not needed
Old Mar 26, 2003 | 08:16 PM
GreenD's Avatar
Default Re: Water pump question (rathead)
my oem gsr waterpump didnt have dowell pins. count the teeth on the gear to make sure u got the right one. the dipshits at pep boys sold me an ls/b20 waterpump then wouldnt take it back cause i threw out the receipt.
ls/b20=19 teeth
b18c=22 or 23 teeth(i cant remember exactly, but its one or the other)
Old Mar 26, 2003 | 08:35 PM
monicle's Avatar
Default Re: Water pump question (GreenDestiny)
hrmm well the gear actually now that i look at them is noticably smaller and has 2 fewer teeth. is this a big deal?
Old Mar 26, 2003 | 08:44 PM
IN VTEC's Avatar
It's 22 teeth. It's marked right on the water pump gear "22T".
My original water pump had the dowel pins.
But, my OEM replacement water pump didn't have the dowel pins pressed in or included. I tried to order them separately, but the ones I got didn't fit....so I put it on without the dowel pins. Same thing with my friend's motor.
Old Mar 26, 2003 | 09:00 PM
B U N M A N G O's Avatar
Default Re: Water pump question (IN VTEC)
pics of my old OEM one
Old Mar 26, 2003 | 09:14 PM
GreenD's Avatar
yes its a big deal. looks like th epepboys dipshits strike again . there wont be enough tension on the timing belt w/ the smaller gear. ive been there . take it back and get the right one. 22 teeth like INVTEC said.
Old Mar 26, 2003 | 10:25 PM
B18EG6's Avatar
What causes a water pump to go bad?
Old Mar 27, 2003 | 05:39 AM
funky49's Avatar
Default Re: Water pump question (B18EG6)
Friction.
It's a bearing. It's a moving part. Moving parts go back after a while.
When you get your new one, why not just move the dowel pins from the OE water pump to your replacement? That's what we did on my LS. My water pump came from a Acura parts department with no dowels.
funk
[Modified by funky49, 9:40 AM 3/27/2003]
Old Mar 27, 2003 | 07:49 AM
ragejed's Avatar
Default Re: Water pump question (funky49)
How come the OEM one has bigger blades? Would it move the collant better?
Joshua Coulson
Feb 11, 2016 11:45 AM
neofreak
Mar 4, 2010 10:43 AM
ranta18
Nov 12, 2009 08:04 AM
monicle
11
Mar 26, 2003 08:49 PM
DC2Monster
Feb 8, 2003 01:17 PM
