Water pump
Old Nov 9, 2002 | 09:33 PM
  #26
3rdGteg's Avatar
Default Re: Water pump (mr_mbuna)
So what is the tricky part about this deal?
Nothing besides the crank pulley, it's a biatch to get off.
Are there timing/alignment issues? Are they easy to deal with or will having them a little off really fock it up?
Yes; "Timing" Belt. Have it off and u can bend your valves, etc. YOU better let a shop do it.
Old Dec 4, 2002 | 05:19 AM
  #27
IntEGNYC's Avatar
Default Re: Water pump (3rdGteg)
my coolant is completely gone even after i topped it off again a week ago. I wonder if this is attributed to a failing water pump, bad radiator, or a failing head gasket.
any ideas?
Old Dec 4, 2002 | 07:16 AM
  #28
Honda Hick's Avatar
Default Re: Water pump (IntEGNYC)
check your oil, if its milky, then the inside of the headgasket went and dont drive it . To see if its the outside of the headgasket, water pump or radiator, the easiest way is to sit it somewhere where you can leave it for a bit and look under teh car. The water pump is on the driver side, rad front, and headgasket is usually on the back of the engine. Also, if u can get under the car check it out. What yr car u got an how many miles, just wondering?
Old Dec 4, 2002 | 10:39 AM
  #29
IntEGNYC's Avatar
Default Re: Water pump (Honda Hick)
88,000 miles going strong. The mechanic told me i need to get my radiator replaced. Will cost $200. Does this sound reasonable. Im assuming they use some aftermarket generic brand but it works.
He told me to change my water pump when i see water dripping when the car is running idle in my drive way. I guess ill have to check periodically. bummer.
Old Dec 4, 2002 | 11:11 AM
  #30
NeoGSR's Avatar
along w/ having the h20 pump replaced and the timing belt, do crank and cam seals at the same time, it will save a lot in labor when everything is already out of the way because the parts are fairly cheap...
seems like a fair price...matters where you bring it, an acura dealer will replace it with OEM, a shop may or may not....my friend spent $300 on this really nice radiator....looks like a lot better build quality than the stock OEM
Old Dec 4, 2002 | 11:56 AM
  #31
Honda Hick's Avatar
i had to replace my rad on my 90, i think it was like $120. its a generic but its cool, it was a dual core, instead of the stock single core. More radiator, the better .
Old Dec 4, 2002 | 08:44 PM
  #32
NateTEG95's Avatar
Replace waterpump when you change the timing belt.
Old Dec 5, 2002 | 09:16 AM
  #33
IntEGNYC's Avatar
Default Re: Water pump (erikgsr)
Don't you have to remove the timing belt to get to the water pump?
Do it yourself, get a helms, not just for this service, but for the future. All of the things listed are very easy, exceot timing belt.
[Modified by erikgsr, 11:29 AM 10/29/2002]
nightfawl
Jan 22, 2015 06:04 PM
dleccord
Dec 28, 2009 03:54 PM
Seks
Aug 9, 2004 12:55 PM
who00knows
Jul 31, 2003 05:39 AM
KooK
Jul 30, 2002 05:13 PM
