vtec sputtering 2nd gear....
Old Mar 13, 2008 | 10:38 AM
tpdc2's Avatar
Default vtec sputtering 2nd gear....
Ok so I have a 2001 gsr mild all motor build. Recently I had a new clutch and flywheel installed. 2 days after I wanted to see how the clutch grabbed so i wrapped out first no problem, then 2nd gear and on the car sputters from 5-6500k sounding like vtec is turning on and off. Any suggestions. I changed the wires and plugs already. Maybe the distributor is causing this? Also I took off my smsp header which my car was tuned on and put an oem cat on also just for the winter. I was wondering if i could have a clogged cat aslo?
Old Mar 13, 2008 | 11:18 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: vtec sputtering 2nd gear.... (tpdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so I have a 2001 gsr mild all motor build. Recently I had a new clutch and flywheel installed. 2 days after I wanted to see how the clutch grabbed so i wrapped out first no problem, then 2nd gear and on the car sputters from 5-6500k sounding like vtec is turning on and off. Any suggestions. I changed the wires and plugs already. Maybe the distributor is causing this? Also I took off my smsp header which my car was tuned on and put an oem cat on also just for the winter. I was wondering if i could have a clogged cat aslo?</TD></TR></TABLE>
check oil level... did you throw a CEL???
most likely its low oil pressure... check that ****, add some and u should be ok...
Old Mar 13, 2008 | 11:26 AM
tpdc2's Avatar
Default Re: vtec sputtering 2nd gear.... (S2KILLA)
sorry to not mention i did check oil, its good. no cels either
Old Mar 13, 2008 | 11:42 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to not mention i did check oil, its good. no cels either</TD></TR></TABLE>
check your vtec pressure sensor... un-clip it and clean it out... plug it back in and give her a try
Old Mar 13, 2008 | 11:43 AM
tpdc2's Avatar
i take it thats by the vtec solinoid
Modified by tpdc2 at 12:56 PM 3/13/2008
Old Mar 13, 2008 | 11:56 AM
tpdc2's Avatar
checked it, its all good didnt fix the problem
Old Mar 13, 2008 | 12:07 PM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">checked it, its all good didnt fix the problem </TD></TR></TABLE>
and ur sure its not oil level??? might be a faulty solenoid... although im pretty sure the CEL would go on cuz of that... did u try engaging in another gear?
Old Mar 13, 2008 | 12:13 PM
tpdc2's Avatar
yeah 1st is good then 2nd and 3rd bog to ****. havent hit any other gears yet. im thinking it the dizzy. ne way to check if the dizzy is working properly
Old Mar 13, 2008 | 01:39 PM
S2KILLA's Avatar
https://honda-tech.com/zerothread?id=1430824
you owe me motha fawka...
Old Mar 13, 2008 | 02:55 PM
tpdc2's Avatar
thanks ill check it out 2mor got school in a lil
Old Mar 13, 2008 | 06:52 PM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpdc2 &raquo;</TD></TR><TR><TD CLASS="quote">thanks ill check it out 2mor got school in a lil</TD></TR></TABLE>
yeah no problem... just keep me updated so i can keep helping u solve this problem
Old Mar 13, 2008 | 08:50 PM
DA_9's Avatar
I had a problem similar to this. This is what fixed it....
One it was the vtec pressure switch or sensor, whatever it is. I figured out that I had to ground that wire, re-chip it and take it out. Fixed the problem.
Old Mar 13, 2008 | 08:59 PM
LsVtecFoti's Avatar
bro, if you havent changed the oil, i'd definitly recomend doing it. And also, take off your vtec cyl. and make sure that little screen is clean.. no cystalization or clogs in it.
Old Mar 14, 2008 | 08:24 AM
tpdc2's Avatar
Default Re: vtec sputtering 2nd gear.... (LsVtecFoti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_9 &raquo;</TD></TR><TR><TD CLASS="quote">I had a problem similar to this. This is what fixed it....
One it was the vtec pressure switch or sensor, whatever it is. I figured out that I had to ground that wire, re-chip it and take it out. Fixed the problem.</TD></TR></TABLE>
Does anybody know where this switch or sensor is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtecFoti &raquo;</TD></TR><TR><TD CLASS="quote">bro, if you havent changed the oil, i'd definitly recomend doing it. And also, take off your vtec cyl. and make sure that little screen is clean.. no cystalization or clogs in it.</TD></TR></TABLE>
Changed the oil less than a 1000 miles ago...
Old Mar 14, 2008 | 08:31 AM
bptotheeng's Avatar
I had a buddy with a similar problem...he said it was the O2 sensor...maybe check yours...
Old Mar 23, 2008 | 11:44 AM
speedysohc's Avatar
ya boy its simple..... 1100 dollar header wit a test pipe. now u have a OBX header wit a cat......
come on now peeps lets think. maybe a clogged cat?
good luck my buy
Old Apr 8, 2008 | 08:00 AM
jc2801's Avatar
good luck with this man, I have the same exact problem, NO CEL, I got new spark plugs and wires, new dizzy, new vtec selonoid and and vtec pressure cyl. and the car has new oil...1st gear doesnt sputter but 2nd and 3rd do when vtec is trying to engage....I've been cracking my head to see what the problem is.
Old Apr 8, 2008 | 08:07 AM
jc2801's Avatar
oh yea try unpluging the vttec selonoid and run the car to make sure it doesn't sputter without vtec, if it doesn't sputter without vtec we have the same exact problem (which I can't figure out)
92Luda
Jan 10, 2007 07:03 PM
SilverPanda
May 28, 2005 10:20 AM
xdeffunkx
Dec 31, 2004 06:46 PM
kseriesDC5
14
Feb 16, 2004 04:52 PM
[626]95-GSR
Feb 15, 2002 09:25 AM
