VTEC problem, clean VTEC selinoid?
Old Jun 28, 2008 | 09:47 PM
karkrazy9's Avatar
Default VTEC problem, clean VTEC selinoid?
ok so VTEC only engages 1st and 2nd gear 1/2 throttle, any time im WOT VTEC does not engage. Any solutions?
prolly gonna seafoam the car and see what that does. is there any way to clean the VTEC selnoid it self or if that would help any? Also this occurs after a fresh oil change so the oil is there....
Old Jun 29, 2008 | 06:09 PM
LSracing94's Avatar
Default Re: VTEC problem, clean VTEC selinoid? (karkrazy9)
you are low on oil most likely
Old Jun 29, 2008 | 06:25 PM
hbcrazy88's Avatar
Default Re: VTEC problem, clean VTEC selinoid? (LSracing94)
sea foam doesnt do anything, its really just a wast of money. check your oil pressure
Old Jun 29, 2008 | 07:35 PM
JuggsxCOmanDO's Avatar
seafoam does noting..
check oil pressure, there is a screen in the vtec solinoid check it.. try someone elses vtec solinoid but most likely its your oil pressure
tigasin
Nov 14, 2008 11:58 PM
JSpekBB4
Oct 30, 2007 10:23 PM
spoonef
Feb 28, 2003 10:01 AM
01-1293
Oct 9, 2002 03:03 PM
r7
Jun 28, 2002 02:24 PM
