Vtec in a GSR question
Old Aug 2, 2006 | 06:12 AM
Shaun's Avatar
Default Vtec in a GSR question
I have a 95 gsr.. im running the stock computer... those of you that have a gsr running the stock ecu... my question is that I hear vtec activate at 4100 , then something esle happens around 6krpm at full throttle like it kicks in again... I want to know what it is, also its doesnt happen sometimes and sometimes it happens..... I need an explanation thanks
Old Aug 2, 2006 | 06:21 AM
trick_db's Avatar
Default Re: Vtec in a GSR question (Shaun)
vtec kick in at 4100 weird, but gsr have a secondary butterfly, second tone
Old Aug 2, 2006 | 06:24 AM
Shaun's Avatar
vtec activates in the early 4100-4400 rpm's , then the second tone after 6krpm, i had the sound after 6k rpm for like a month then it goes away.. then comes back, i think it has something to do with oil maybe
Old Aug 2, 2006 | 06:45 AM
Lan's Avatar
Lan
Default Re: (Shaun)
Pull your vtec cylinoid off and clean it, check for debris
Old Aug 3, 2006 | 03:56 AM
Shaun's Avatar
i just changed my oil, the second tone came back, i clean the vtec solenoid with parts cleaner
Old Aug 3, 2006 | 04:46 AM
JmurGSR98's Avatar
how long have you had your car? a guy i work with said he got his computer chipped so that the vtec will come on at around a little past 4000 rpm. maybe the previous owner did something like that.
Old Aug 3, 2006 | 04:51 AM
Shaun's Avatar
i had it for about 7 months... i belive the secondaries open at around 4400
Old Aug 3, 2006 | 08:56 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (Shaun)
gsr vtec is supposed to kick in at 4400 and the secondary butterfles are supposed to open around 5700
Old Aug 3, 2006 | 09:12 AM
H23 Power's Avatar
Default Re: (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one &raquo;</TD></TR><TR><TD CLASS="quote">gsr vtec is supposed to kick in at 4400 and the secondary butterfles are supposed to open around 5700</TD></TR></TABLE>
finally...
these are the sounds you are hearing.
Old Aug 3, 2006 | 09:18 AM
-Championship-'s Avatar
76.169.175.137
Default Re: (H23 Power)
VTEC at 4400 and secondary butterflies at around 6000, its not vtec just more airflow, it's oil pressure at 4400 and little throttles open at 6000 or so (secondary butterflies), the secondary butterflies should open all the time, then again make shure you have good amounts of oil, the ecu looks for the MPH your in, oil pressure, and a specific RPM (4400 in this case), then it's nothing but, VEEEEEEEEEEEEEEEEEETAAAAAAAAAAAAK!!!!!!!!!!!!!!!!! !
Old Aug 3, 2006 | 09:24 AM
Danziver's Avatar
Default Re: (Shaun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">i just changed my oil, the second tone came back, i clean the vtec solenoid with parts cleaner</TD></TR></TABLE>
I need to do this too.
TastyDragon
Oct 25, 2006 04:12 PM
90teg
Jan 5, 2006 03:09 PM
C1power
Jan 3, 2006 07:15 PM
t_lager
Aug 5, 2005 02:54 PM
GreenGSR
Aug 11, 2002 06:45 AM
