VSS cable sensor?
Old Jan 8, 2008 | 06:52 PM
jordanitr's Avatar
Default VSS cable sensor?
I have a 91 integra, and I just replaced the old speeometer cable cause it was old and crappy. Anyway when I pulled the old one out it was kinda hard to get out..
The new one will go in, but when I put the clip in I can still pull the cable with the slightest pull, I did this like 10 times and it still slides out, the clip is still good too.
I checked my the vss in my gauge cluster and its hooked up good too..
So when I install the cable in the VSS is it supposed to click or just slide in then put the clip on?
Old Jan 8, 2008 | 08:06 PM
HONDRETTI's Avatar
Default Re: VSS cable sensor? (jordanitr)
it will go in just far enough, not neccessarily click but you'll know, then make sure the rubber boot is secure
Old Jan 8, 2008 | 08:20 PM
jordanitr's Avatar
Default Re: VSS cable sensor? (HONDRETTI)
Thank you
EFS463
10
Jun 26, 2012 07:01 PM
shai x boi racer
Jul 14, 2005 04:52 PM
jcrou
Dec 17, 2004 08:56 AM
DOHCRX
Mar 28, 2003 08:22 PM
