Violation Sticker HELP :(
Old Aug 14, 2003 | 09:46 PM
yellowbuffalo's Avatar
Default Violation Sticker HELP :(
Tonight as I was walking to my car to get out after working 10 hrs straight. I see this ******* violation sticker on my window. I was parked in the right spot but some ******* from security put it there. I work at a hotel, anyway is there a special way to get it off my window? without messing up or scraatching my window?
Old Aug 14, 2003 | 09:50 PM
216.226.142.95:27016's Avatar
Default Re: Violation Sticker HELP :( (yellowbuffalo)
its only a sticker. peel it off, rub it off, blow dry it to make it soft.
Old Aug 14, 2003 | 09:56 PM
thaiphob's Avatar
Nikon!!!
Default Re: Violation Sticker HELP :( (216.226.142.95:27016)
get a spray bottol with water and spray the sticker till it gives up and falls off!
Old Aug 14, 2003 | 09:58 PM
Hites
Guest
Posts: n/a
Default Re: Violation Sticker HELP :( (thaiphob)
just yell at the sticker til you get its self esteem so low that it runs to its room crying.
Old Aug 14, 2003 | 10:01 PM
garados's Avatar
use a razor blade, and just scrape it away. Also try some goof off.
Old Aug 14, 2003 | 10:04 PM
Default Re: Violation Sticker HELP :( (garados)
I also forgot to say its not those stickers that just come off they have some pretty strong glue.
Old Aug 14, 2003 | 10:24 PM
The-LS's Avatar
Default Re: Violation Sticker HELP :( (Hites)
I'd use a razor blade first, that will take off anything without harming the window. If that doesn't work than I'd try: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hites &raquo;</TD></TR><TR><TD CLASS="quote">just yell at the sticker til you get its self esteem so low that it runs to its room crying.</TD></TR></TABLE>
Old Aug 14, 2003 | 10:39 PM
Gabe_'s Avatar
Default Re: Violation Sticker HELP :( (Black-LS)
I highly recomend this stuff. It takes off any stickery, type stuff with the greatest of ease. Also it's safe for every finish I have tried it on... even my cars paint. The bottle pictured cost me $3.19+ tax.
Old Aug 14, 2003 | 10:44 PM
Calavera's Avatar
Default Re: Violation Sticker HELP :( (Gabe_)
do they sell goo gone at pepboys? I've only seen them at home depot and stuff.
Old Aug 14, 2003 | 10:59 PM
Gabe_'s Avatar
Default Re: Violation Sticker HELP :( (Calavera)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">do they sell goo gone at pepboys? I've only seen them at home depot and stuff. </TD></TR></TABLE>
I am not sure. I don't recall seeing it there. I picked mine up at Meijer... for those of you not from MI or the surrounding states Meijer is sorta like a 24 hour wal mart, only less white trashy.
Old Aug 15, 2003 | 03:01 AM
tilt's Avatar
goo gone, simple green, 3m adhesive remover... any of them will work fine.
Old Aug 15, 2003 | 03:08 AM
DCStreetHtch's Avatar
Default Re: Violation Sticker HELP :( (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">goo gone, simple green, 3m adhesive remover... any of them will work fine.</TD></TR></TABLE>
what he said!
-Bryan-
Old Aug 15, 2003 | 07:38 AM
BloodRedTeg's Avatar
Default Re: Violation Sticker HELP :( (EGStreetHtch)
alchohl works best... it melts away the sticky stuff
Old Aug 15, 2003 | 08:52 PM
Default Re: Violation Sticker HELP :( (BloodRedTeg)
I used goo gone and soaked it up with half a bottle. Waited 10 minutes sticker came off all at once. Thanks guys your the best.
Old Aug 15, 2003 | 09:52 PM
Heisdan's Avatar
SPRAY PAINT THE WINDOW BLACK.. lol you can't cut a window w/out using a diamond.. .. use a razor blade.. (unless u have tint, only on the inside lol) .. glass cleaner and razor.. 3 seconds.. gone .. (I detail.. too much skill w/ blades hahah.. )
Old Aug 15, 2003 | 11:54 PM
tegasaurus's Avatar
Default Re: (Heisdan)
if you get any of that goo gon or goof off on your paint, do NOT wipe it off, set a paper towel on it and let it absorb.
Just use a really strong soap (dawn) and water, rub the soap into the sticker, around it and so on for about 2m inutes, then start scraping at it with a razor blade and you'll be good as new
Old Aug 16, 2003 | 01:18 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gabe_ &raquo;</TD></TR><TR><TD CLASS="quote">I highly recomend this stuff. It takes off any stickery, type stuff with the greatest of ease. Also it's safe for every finish I have tried it on... even my cars paint. The bottle pictured cost me $3.19+ tax.
WILL THAT TAKE SAPP OFF?
Old Aug 16, 2003 | 01:19 AM
integraL's Avatar
for the razor trick, make sure its at a 45 degree angle or less.
Old Aug 16, 2003 | 06:58 AM
VTECorona's Avatar
Default Re: (integraL)
get some windex and goo gone and some razor blade scapers. i remove some pretty aggressive window tint at work and thats how we get the glue off of the window.
Old Aug 16, 2003 | 07:25 AM
Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heisdan &raquo;</TD></TR><TR><TD CLASS="quote">lol you can't cut a window w/out using a diamond.. .. hahah.. )</TD></TR></TABLE>
but you can sure scratch it.
Old Aug 16, 2003 | 11:39 AM
tegmech's Avatar
Default Re: Violation Sticker HELP :( (integraL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">
WILL THAT TAKE SAPP OFF?</TD></TR></TABLE>
The best and easiest stuff to get sapp off that i have found is mopar(my mom drives a sebring) bug and tar remover. You have to use almost no force, and a bodyshop said that it doesn't hurt your paint.
Old Aug 16, 2003 | 01:33 PM
GS-R Jay's Avatar
Nail polish remover or any kind of rubbing alcohol will take it off really easily with a cotton ball. Just make sure none of it gets on the paint.
JDMJUNKIEMONKIE
15
Nov 6, 2009 06:16 PM
dopamean
11
Jan 2, 2009 07:27 PM
LiKe_WhOa!
Jun 25, 2004 11:12 AM
JdmLsPwr425
Mar 10, 2004 07:34 PM
m0dr0cker
16
Oct 21, 2003 09:55 AM
