Vibration, Help?
Old Sep 22, 2003 | 02:28 PM
Int3Gra147's Avatar
Default Vibration, Help?
Alright, i have a 96' gsr, just recently a vibration started comming from the passenger side. It really shakes the car bad, like the shifter stick goes crazy too. It happens like between 4k and up. The axles look fine and i was thinking possible motor mounts, but im not sure, any suggestions? Thanks Adam
Old Sep 22, 2003 | 04:32 PM
florduhdude's Avatar
Default Re: Vibration, Help? (Int3Gra147)
i'd check the simple things first, like the balance and roundness of the tire. Tires can throw weights and that will cause a vibration, and they can go out of round, that will do the same. Try moving that tire to the back and see how it drives.
Old Sep 22, 2003 | 05:58 PM
dc2twincam's Avatar
Default Re: Vibration, Help? (florduhdude)
yeah do an inspection on the wheels and tires, then check yer rotors to see if they're warped to hell............
Old Sep 23, 2003 | 03:27 AM
JimBlake's Avatar
Does it change when you're on the gas vs. coasting in gear? Does it change with road speed - say at the same rpm in different gears? Does it change if you apply the brakes (without disengaging the clutch)?
Old Sep 23, 2003 | 06:50 AM
94ls's Avatar
be more specific with that vibration...does it only happen when you're moving up through the rpm range or does it happen constantly? does it happen when you brake? short guessing it, i'd say ck the tires first. that can def have an impact.
Old Sep 23, 2003 | 10:14 AM
Int3Gra147's Avatar
Default Re: Vibration, Help? (94ls)
Thanks guys for your sugesstions, tryin to be more specific. The vibration only happens when acellerating, like if i start going (the vibration is happen at this point) then if i were to get off the gas the vibration goes away, or aleast isnt nearly as bad. I had just reaplced the tires as well, so possible they could have fucked up the wieghts and that could be it, im gonna rotate the tires and see what effect that has. Let me know if you guys have any more suggestions. Thanks again guys, Adam
Old Sep 24, 2003 | 05:50 AM
94ls's Avatar
i just want to verify that its not a rattle from underneathe the car right? you are saying the actual car vibrates correct, not rattles? get back to us on that
Old Sep 24, 2003 | 06:27 AM
JimBlake's Avatar
Another suggestion to clarify something. Does it follow engine speed or road speed? Accelerate from 4k to 5k rpm in 2nd gear, then from 4k to 5k in 3rd, then 4th... This way you're at the same engine speed at different road speed.
If it goes with engine speed, then look for things like exhaust sytem hitting somewhere, or even misfiring at certain rpms.
If it goes with road speed, then look for loose/worn inner drivers, bad CV joints, wheel bearings, tires, etc...
Old Sep 24, 2003 | 06:59 AM
YellowGiser's Avatar
Default Re: Vibration, Help? (JimBlake)
Old Sep 24, 2003 | 08:52 AM
Int3Gra147's Avatar
Default Re: Vibration, Help? (YelloWGSR)
Its def. a vibration, not a rattle. Alright say im driving on the highway, im on the on ramp accelerating. at like 4k rpm 3rd gear, flooring it, its vibriting, shift to 4th still virbating. and same in 5th. If im just crusing on the highway at whatever speed, no vibration. If i try to accelerate at any speed, any gear it virbrates. And to claify the vibration shakes the whole car, mostly in the passger side front wheel area.
Old Sep 24, 2003 | 09:12 AM
JimBlake's Avatar
What about the RATE of vibration? Is it the same at 4krpm, no matter what gear you're in? That tells you whether it's anywhere in the wheels, brakes, or driveshafts. Because the wheels & axles spin faster when you're in the higher gears.
Old Sep 24, 2003 | 04:47 PM
Int3Gra147's Avatar
no it really doesnt seem to go away as i go though the rpm band. the vibration seems to stay pretty constant when on the gas.
Old Sep 25, 2003 | 03:36 AM
JimBlake's Avatar
Misfiring under load? Check your plugs, wires, cap, stuff like that... Do you have low compression in one cylinder?
Originally I was kinda guessing driveshafts or tire problems, but those would vibrate at a higher rate with higher road speed.
b20hatchek
Sep 5, 2010 11:19 AM
dc2long
Sep 30, 2009 07:49 PM
nObOdy65
May 12, 2007 07:31 PM
betep
Feb 14, 2007 04:24 AM
tequilakid
Oct 1, 2005 07:19 PM
