Very odd Speedometer problems...
Old Feb 19, 2009 | 07:42 AM
VTcivicHB's Avatar
Default Very odd Speedometer problems...
My speedometer has some really weird issues. At any given point it is usally 15 to 20 mph off but if it's cold started I've seen it almost 50 mph off (on the highway). What could be causing this? I replaced the VSS and it ended up not being the problem. Any help would be much appreciated.
Cliffs
-VSS is 15-20mph off, even worse when it's cold
-Stock tire size & rims
-95 LS w/B16 transmission
-New VSS
-Also my temp gauge doesn't work (if that matters)
-odometer is accurate
Old Feb 19, 2009 | 08:02 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Default Re: Very odd Speedometer problems...
Is this a DA or DC?
cel?
How's the cranking?
Old Feb 19, 2009 | 08:29 AM
DC_Legacy's Avatar
Cliffs
-New VSS
Maybe its a short in the wiring between the gauge, VSS, and ECU.Try trouble shooting the circuit with a voltmeter if the manual gives you a diagnostics checklist. I've never seen a partial failure of the gauge, but after I installed my Alpine headunit I had a few instances where my dashcluster completely shorted out due to a lose wire that wasnt capped or grounded before installing the stereo, that I've since took care of.
Old Feb 19, 2009 | 08:37 AM
HONDRETTI's Avatar
OP stated had a 95 = dc
inaccurate speed readings would result in inaccurate odometer readings btw. if the vss is good and installed properly i would try a different cluster and/or ecu, see if it still does it.
civic4dr337
Apr 16, 2022 05:59 PM
SIRC 2o9
Sep 3, 2010 07:36 AM
spidy3
Mar 11, 2008 06:43 PM
96electronH
Feb 3, 2008 05:17 PM
JohnD1079
Apr 4, 2007 08:27 PM
