valves
Old Jun 8, 2005 | 10:35 AM
huge230's Avatar
Default valves
I just finished porting and polishing my cylinder head and would i be right in assuming that nothing can be done to the valves unless i take them to a shop?
Old Jun 8, 2005 | 10:43 AM
HoUTX98GSR's Avatar
Default Re: valves (huge230)
did you p&p it yourself?
Old Jun 8, 2005 | 11:01 AM
huge230's Avatar
Default Re: valves (HoUTX98GSR)
yes
Old Jun 8, 2005 | 12:12 PM
TypeRobert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">yes</TD></TR></TABLE>
Hey i want to do that too how did you do it was there like a kit? was it your first one hmmm tell us a lil more
Old Jun 8, 2005 | 12:17 PM
huge230's Avatar
Default Re: valves (slperhybrid)
no kit just use a dremel and smooth out and slightly enlarge the ports
Old Jun 8, 2005 | 02:08 PM
HoUTX98GSR's Avatar
wow.. did you research before you did it or did you just go gung ho on it?
I read about it because i wanted to do it and i decided it was a good idea not to do it.. to gain any power you have to use a flowbench to test it to even gain power. If you change the shape of the chamber or make it too smooth or too big you could harm your performace rather than gain any.
unless i was just going to boost it i wouldnt even touch it..
Old Jun 8, 2005 | 02:20 PM
99exd16y8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">no kit just use a dremel and smooth out and slightly enlarge the ports</TD></TR></TABLE>
wow i would never do that to my motor, you sir are a brave soul, more props to you if it comes out right, post up some pics.
Modified by 99exd16y8 at 3:42 PM 6/8/2005
Old Jun 8, 2005 | 05:01 PM
TypeRobert's Avatar
could you possible loss perfoenmance by doing this? If so i dont got a problem givin a try being very careful of course
BTW the reason i asked about a kit was because once i though i saw inline4 sell a DIY P2P kit but im not even sure if it was them so
Old Jun 9, 2005 | 11:03 AM
HoUTX98GSR's Avatar
the chambers are well shaped from the factory.. ive read that its bad to smooth them too much because the rough surface is there to cause turbulance to mix the fuel/air. The shape is also important because it maximizes the flow of the air.. if you are going to do it yourself its best just to take the imperfections out and just port match the intake/exaust manifolds.
Johnny_9
11
Aug 19, 2008 03:00 PM
defnu
10
Mar 11, 2008 05:49 PM
NirVTEC
May 5, 2007 05:36 PM
thaiphob
Dec 2, 2005 01:15 PM
dirtyturtle
11
Nov 26, 2004 02:26 PM
