Valve Cover
if i take my valve cover off do i have to change the gasket? because i took it off and adjusted my valves and put it back on with the same one and there are not any leaks that i see. Any Thoughts
Ive taking mine off plenty of times to do valve adjustments and never changed my gasket. As long as u have it tucked in the groove of the valve cover and its not ripped u should be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ir0nmanx »</TD></TR><TR><TD CLASS="quote">Do you have to replace it everytime you take off your valve cover?
EDIT: Nevermind I just saw the post above.</TD></TR></TABLE>
No you do not need to change it. It's just a rubber gasket, it is reuseable. Just make sure you wipe down both the gasket AND the head where the gasket goes with brake cleaner. You don't want oil there when you put the gasket back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">
x2 and dont use any sealent what so ever you dont want that gunk in your head
</TD></TR></TABLE>x2 and dont use any sealent what so ever you dont want that gunk in your head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dealer Leaf »</TD></TR><TR><TD CLASS="quote">x2 and dont use any sealent what so ever you dont want that gunk in your head</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B series FTW »</TD></TR><TR><TD CLASS="quote">just make sure you use Honda bond around the corners</TD></TR></TABLE>
^^^Not just the outside corners, but also the middle ones (the ones that go around the camshafts). You don't need a lot, just a light coating at those corners.
What about around the spark plugs. I pulled one of the spark plug wires out today and there was some oil on it. is it possable that i did not set it on strate because there is also some oil on the back of the cover where the washer and the nut is. and it also did not seam like it was lineing up on the two center studs.
depo
Mar 23, 2019 09:37 PM
Shaguar47
May 28, 2007 08:47 AM
