V-TECH ON OBD0
Old Feb 5, 2005 | 01:17 PM
ravin's Avatar
Default V-TECH ON OBD0
Hello Guys How can I hook up a VTECH Pressure switch,
and VTECH Solonide on a OBD0 for a 1990 Integra that has
a 94 DEL SOL moto.
Thanks
Old Feb 5, 2005 | 01:20 PM
DynastyRacer22's Avatar
Default Re: V-TECH ON OBD0 (ravin)
why would you wanna hook up a phone to your motor? its Vtec and aint the 90 integra come dual and the delsol a single? haha weird swap but whatever
Old Feb 5, 2005 | 01:26 PM
CdTriX's Avatar
why would you put in a weaker motor? and what engine code is the delsol motor... or at least do you know what model of del sol the motor came from?
btw it's VTEC all capitals..
Old Feb 5, 2005 | 01:33 PM
eymnewdc4's Avatar
Default Re: (CdTriX)
what is VTECH? i think my old phone had that, it broke though. try VTEC.
Old Feb 5, 2005 | 01:40 PM
riceball777's Avatar
first you need a obd0 vtec ecu
which is either a pr3 or a pw0 (JDM only)
Old Feb 5, 2005 | 02:14 PM
LSvtec03's Avatar
Default Re: V-TECH ON OBD0 (DynastyRacer22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DynastyRacer22 &raquo;</TD></TR><TR><TD CLASS="quote">why would you wanna hook up a phone to your motor? its Vtec and aint the 90 integra come dual and the delsol a single? haha weird swap but whatever</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CdTriX &raquo;</TD></TR><TR><TD CLASS="quote">why would you put in a weaker motor? and what engine code is the delsol motor... or at least do you know what model of del sol the motor came from?
maybe because some del sols came with b16s.
btw it's VTEC all capitals.. </TD></TR></TABLE>
vtec vtec vtec....
Old Feb 5, 2005 | 03:09 PM
3.504's Avatar
Default Re: V-TECH ON OBD0 (LSvtec03)
you'll have to get an obd0 vtec ecu. can find them from many jdm junkyards like http://www.passwordjdm.com http://www.jdmshit.com and many others. you can also get an obd0-obd1 conversion harness and run one of the many obd1 vtec ecu's. then you'll have to wire outside the harness into 2 pins for both the solenoid and the pressure switch. if you want the pins just reply to this, if you dont know anything about ecu pins, hand the car over to someone that does, like a reputable shop.
Old Feb 5, 2005 | 04:16 PM
IggyBcool's Avatar
hey i used to have a slime green vtech!!!!!!!!!
Old Feb 5, 2005 | 05:03 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (99LStegra)
IBTL
apbtwhiskey
May 30, 2013 11:12 AM
d15bdelsol
Apr 25, 2007 08:41 AM
TheDelSlo
Oct 9, 2005 08:59 AM
Wysper
24
Jun 11, 2005 10:48 AM
delsolrmp
Nov 15, 2003 07:46 AM
