V-TEC not engaging!!!
Old Jun 6, 2006 | 06:05 PM
.I.Need.Money.'s Avatar
Default V-TEC not engaging!!!
Okay, so I just finished doing a compression check on my car, thought everything was fine, it wasn't. I noticed that the check engine light came on when I started it up, thought to myself, hmmm... that's strange. Then I went and took it for a ride and noticed the V-TEC will not engage at all!!!!!! I reved it high and got nothing! What the hell is going on!?!?!
Old Jun 6, 2006 | 06:07 PM
DSEA2's Avatar
Default Re: V-TEC not engaging!!! (93EGB18C1)
check your oil level. was the oil light on?
Old Jun 6, 2006 | 06:09 PM
akstunt600's Avatar
code 21 or 22?
those r vtec sol and pressure
it will also not go into vtec if some other CEL's are on
pull the codes and get back to us
Old Jun 6, 2006 | 06:23 PM
Oil was fine, is there some way I can check the codes myself without having to take it somewhere???
Old Jun 6, 2006 | 06:25 PM
DSEA2's Avatar
Default Re: (93EGB18C1)
there is a blue plug under the dash on the passenger side. if you use a wire to jump it you car read the code by turning the key on and counting how many times the check engine light flashes. if you count the flashes i will tell you what the code is. because the list is too long to type right now.
edit: you can use a paper clip to jump it.
Old Jun 6, 2006 | 06:27 PM
Also, my car has been blowing smoke out the back like no other. Straight laying down a cloud. Smells like oil. Checked the compression today and it was fine. What is causing the problem? And if I throw a CEL, will that stop my V-tec from engaging???
Old Jun 6, 2006 | 06:29 PM
DSEA2's Avatar
could be a problem with the vtec solenoid or pressure switch. code P1259 (22 blinks) is a vtec system malfunction. i would say check the code.
Old Jun 6, 2006 | 06:31 PM
akstunt600's Avatar
cel = no vtec
^ for the most part... only 2 or 3 codes will still allow vtec to crack
that cloud is prolly carbon form un-burnt fuel
now my guess is code 3 or 7, which would be map or tps
Old Jun 6, 2006 | 06:33 PM
akstunt600's Avatar
oh btw this is how u read the codes
1 long blink = a double digit #
like ---,- = code 11
---,---,-,- = 22
-,-,- code 3
Old Jun 6, 2006 | 06:36 PM
DSEA2's Avatar
Default Re: (akstunt600)
^^ yea hes correct
Old Jun 6, 2006 | 06:46 PM
Code 21???
Old Jun 6, 2006 | 06:48 PM
What's that mean? Did I mess something up doing the compression check???
Old Jun 6, 2006 | 06:50 PM
DSEA2's Avatar
is your car obd1? or 2
Old Jun 6, 2006 | 06:51 PM
akstunt600's Avatar
21= vtec pressure,
1.) the switch may have gone bad, or wiring may have come undone
2.) u maybe losing oil pressure< bad oil pump 3.) buildup and grime or rod bearing have cloged the screen in your vtec solenoid housing.
4.) your using a heavy weight oil like 50w
Old Jun 6, 2006 | 06:52 PM
DSEA2's Avatar
Default Re: (SpoonDC4)
if its obd1 it is throwing the "Variable Valve Timing and Valve Lift Solenoid". corrective action "check vtec solenoid" and there is no code 21 for obd2
Old Jun 6, 2006 | 06:53 PM
DSEA2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">21= vtec pressure,
2.) u maybe losing oil pressure&lt; bad oil pump 3.) buildup and grime or rod bearing have cloged the screen in your vtec solenoid housing.
4.) your using a heavy weight oil like 50w</TD></TR></TABLE>
code 22 is the pressure switch.
OBD-I I'm uing Syntec 20-50 I think. Now what?
Old Jun 6, 2006 | 06:55 PM
DSEA2's Avatar
check your vtec solenoid? wires, etc.
Old Jun 6, 2006 | 06:58 PM
How might I do that?
Old Jun 6, 2006 | 07:00 PM
DSEA2's Avatar
im not sure how to check the solenoid itself. but i would just check to make sure the wire is intact. test continuity from that to the pin on the ecu.
Old Jun 6, 2006 | 07:04 PM
akstunt600's Avatar
solenoids dont ever really go bad but the pressure switches do
oil pump failure is the second most likely factor
yes there is a code 21 for odb2 and obd 1
if u feel the need to test the solenoid fell free, just disconnect the wire and unbolt the 3 screw on top of the solenoid housing and jump the wire to ur + battery terminal it should click
but like i said these very very rarely fail
Old Jun 6, 2006 | 07:07 PM
akstunt600's Avatar
spoon, i do this everyday its switch 1st sol. 2nd, 21 then 22
Old Jun 6, 2006 | 07:09 PM
Good info, but I'm lost. Where is the solenoid located? How much is this going to cost me? How long can I drive the car like this? And how did this happen from checking the compression?
Old Jun 6, 2006 | 07:17 PM
akstunt600's Avatar
its probably not related to ur compression check, unless u knocked a wire loose
did u unplug ur dizzy when u did the test b/s u should have b/c u could have burnt out ur icm in the dizzy
was it a swapped car? b/c there is more of a chance for unorigninal wiring to be knocked around
the solenoid is located behind ur dizzy on the left hand side of the motor
idk how much its gonna cost
cheap if its wiring
but the pressure switch is about 70-100 brand new form honda if thats the problem
if its ur oil pump well thats not fun and its over 600 after new t-belt and pump and labor
Old Jun 6, 2006 | 07:18 PM
akstunt600's Avatar
your motor will be perfectly fine u can drive it everyday like this just WATCH your oil pressure light.
be extra careful if this is an ls/vtec b/c they may not have upgraded to the gsr oil pump
