Using p75 ecu with a b18a1?
Old Jun 1, 2014 | 07:49 PM
gooblinn258's Avatar
Default Using p75 ecu with a b18a1?
So is there 2 types of p75 ecu's, one thats obd1 and obd2. Cause I have a b18a1 that came out of a 92 integra ls. So apparently the ecu is for the b1's is this ok that im running a b1's ecu for an a1?? Any differences? Is there a way the ecu could be obd2 and there converted it somehow?
Old Jun 2, 2014 | 04:27 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Using p75 ecu with a b18a1?
The ECU doesn't care if the motor is OBD1, OBD2, a rotary, a jet, or a turkey and cheese sandwich. As long as all the sensors respond and react properly, it's happy to run it.
Listing what type of car you have helps.
Edit: IIRC, B1's are OBD1
Old Jun 2, 2014 | 09:15 AM
ZLboosted_EG's Avatar
What's your question exactly? Do you want to know what ecu to use? Yes, you can run a B18B ecu(p75) on a B18A (pr4 I believe). Just use the correct ecu for that chassis
Old Jun 2, 2014 | 11:13 AM
What you mean correct edu for chassis. Im using p75 in a civic for a b18a1.
Old Jun 2, 2014 | 12:09 PM
B serious's Avatar
I was unaware that the civic was only made for one year and in one model.
Old Jun 2, 2014 | 01:18 PM
fcm's Avatar
fcm
Old Fart
LOL, like pulling teeth, or maybe the year of the car is secret.
Also would help if we know MM&Y of car engine was out of, was it auto or 5 speed, is the civic auto or 5 speed.
OP, You can't give too much info on car and car engine is out of, every little bit helps. 94
Old Jul 25, 2021 | 07:20 AM
Krazymonkey227's Avatar
Hey I know I'm bringing a dead thread back but its fitting so I have a b18a1 with an automatic trans I'm not manual swapping yet but I would like to run a p75 for chipping later and manual swapping but. Since I plan on running the obd1 p75 am I ok running everything I got from my da9 tcm too or will that not work
dndn
Mar 21, 2009 10:56 AM
getnasty
Dec 26, 2005 07:59 PM
AG3_Teg
Mar 29, 2005 07:18 PM
43MA
Oct 30, 2002 04:58 AM
gsr squirrel
Oct 8, 2002 06:45 PM
