usdm to jdm front conversion??
Old Mar 18, 2009 | 06:04 PM
luisrblue's Avatar
Default usdm to jdm front conversion??
usdm to jdm front conversion i believe its what its called. my car is the green/gray one but i would like the front changed to the white car's front. around how much would it be and who does these types of jobs?
Old Mar 18, 2009 | 06:10 PM
j_bizach's Avatar
Default Re: usdm to jdm front conversion??
You should be able to get most shops to do it as all it reallly involves is cutting out the core support and welding the new one on then replacing the hood fenders bumper and hood. It depends you could proly get everything welded and bolted up for 1500-2 with the kit and installed and painted 2-3. Ur gunna hav to buy the kit from someone who sells it then take it to a shop and have them do it unless u plan on installing the core support urself then having a shop paint it.
bmwe362006's Avatar
I can do it for you. If you want a clean front u need to spend about 1200. shitty ones u can get for 900.
Old Mar 18, 2009 | 06:15 PM
luisrblue's Avatar
oh okay. does this de-value the car? do i have to put this "job" on the title or somethin?
Old Mar 18, 2009 | 06:16 PM
luisrblue's Avatar
can i get those kits like at ebay or somethin? im located in el paso tx in case anyones from here as well
Old Mar 18, 2009 | 06:17 PM
j_bizach's Avatar
lol nope if the cars clean it can add to the sellabilty and sometime valuve but more sellabilty of the car. No title brand ness.
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Try searching and look in the Integra FAQ. This has been covered hundreds of times.
Miracle
Nov 19, 2006 01:36 PM
whiteknightef
Aug 21, 2006 11:54 PM
crx-treme
Jun 12, 2005 02:09 PM
itr-j
Jan 21, 2003 05:34 AM
