up compression?
my setup so far-
98 b18c1
i/h/e/c/im
01 type r cams
skunk 2 IM
70mm TB (spoon or itr bored to 70, not sure, bought it use)
msd sci ignition
01 type r ecu
thinking about rising my compression a little, like changing my head-gasket.
just need some opinions. TIA for the replies
98 b18c1
i/h/e/c/im
01 type r cams
skunk 2 IM
msd sci ignition
01 type r ecu
usdm or jdm p73 slugs would be a good addition, either one use a 2 ply gasket. p30's or pr3's will do the same. if you can, have the head ran through then put it back together and strap it to a dyno. should turn some really nice numbers
MysteryWagon
Feb 11, 2005 09:18 AM
Chillinit
11
Oct 31, 2004 01:01 PM
