um..is this normal?!
Old Feb 10, 2004 | 01:57 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default um..is this normal?!
i have a 95 integra and i just changed my clutch today because the old one blew up. and well..it's 3am now and i need some help. i had the car on jackstands and i just finished putting the wheels on. then i turn one of my tires for the hell of it and the other wheel spins the opposite direction?? um is this normal or did i screw somethin up when i changed the clutch? i dunno..i got freaked out by what happened and im hella tired right now. help me out guys!
Old Feb 10, 2004 | 02:04 AM
FireMedic's Avatar
Default Re: um..is this normal?! (b2o-vtec)
Oh my god, I can't believe you made this mistake, you need to immediately take your car to a shop..
No really though, Its normal :-P
Old Feb 10, 2004 | 02:13 AM
Caoboy's Avatar
-Intl Steve Krew
Loved
muahhah..i knew that...
Old Feb 10, 2004 | 05:13 AM
mr.beeks's Avatar
Default Re: (b2o-vtec)
sounds like you shitted on your pants for a minute..
LOL
Old Feb 10, 2004 | 05:27 AM
meltman's Avatar
Default Re: um..is this normal?! (FireMedic)
haha, NOOO your car is DOOMED!
Old Feb 10, 2004 | 05:31 AM
ragejed's Avatar
Default Re: um..is this normal?! (meltman)
Isnt that the differential that does this?
Old Feb 10, 2004 | 05:32 AM
IntEGNYC's Avatar
Default Re: um..is this normal?! (ragejed)
a one second poopie
Old Feb 10, 2004 | 05:59 AM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b2o-vtec &raquo;</TD></TR><TR><TD CLASS="quote"> then i turn one of my tires for the hell of it and the other wheel spins the opposite direction??</TD></TR></TABLE>
hAH reaLLY?
Old Feb 10, 2004 | 09:08 AM
PatrickGSR94's Avatar
Community Builder
Active Streak: 60 Days
if you spin one wheel and the other side spins the opposite way, that means the car is in gear, and yes it's the differential that causes that. I'm not sure if an LSD acts the same way when in gear and wheels off the ground, but I know an open diff. does that.
Old Feb 10, 2004 | 09:22 AM
ThePro's Avatar
Default Re: um..is this normal?! (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">if you spin one wheel and the other side spins the opposite way, that means the car is in gear, and yes it's the differential that causes that. I'm not sure if an LSD acts the same way when in gear and wheels off the ground, but I know an open diff. does that.</TD></TR></TABLE>
With my LSD when it is in gear and I turn one wheel the other wheel turns the same direction. With an open diff it turns the opposite direction. I wish I knew the mechanics of why.
Old Feb 10, 2004 | 10:06 AM
typeR#0427's Avatar
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you shitted on your pants for a minute..
LOL
Hell I would have, a little pant Spackle keeps everyone in check though
Old Feb 10, 2004 | 10:52 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">... I'm not sure if an LSD acts the same way when in gear and wheels off the ground, but I know an open diff. does that.</TD></TR></TABLE>An LSD should work the same way. There's just plenty of resistance if you want to turn it fast, depending on what type of LSD.
With an open diff, in NEUTRAL, it might go either way. The drag of the diff gears, vs. the drag of the tranny gearsets, vs. the drag of the opposite brake... I guess usually the opposite brake has the most drag, the opposite wheel doesn't spin, and the transmission spins. With an LSD in neutral, the LSD might have enough drag to spin the opposite brake, then the opposite wheel turns the same way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro &raquo;</TD></TR><TR><TD CLASS="quote">With my LSD when it is in gear and I turn one wheel the other wheel turns the same direction. With an open diff it turns the opposite direction. I wish I knew the mechanics of why.</TD></TR></TABLE>Are you sure it's in gear when you do this? With an engine installed so the input shaft can't turn?
leroyb
15
May 31, 2007 09:38 AM
civdub21
May 11, 2007 12:16 PM
Pilky
Sep 1, 2006 12:16 PM
efyou
Dec 24, 2005 10:41 AM
Bbasso
Mar 1, 2004 05:06 PM
