type r valve train question
Old May 22, 2005 | 04:47 AM
bankhead83's Avatar
Default type r valve train question
I have a LSVTEC but I'm going boost I want to know if is a good idea to put all the type r internal in the head for boost, I'm building the bottom end as well,
Old May 22, 2005 | 05:57 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: type r valve train question (bankhead83)
Regarding internals, only the valve springs and intake valves differ from a B18C1 head . I'm not sure about the B16A heads. How high do you plan to rev?
Check the part numbers here:
http://www.acuraparts247.com
Old May 22, 2005 | 03:34 PM
bankhead83's Avatar
Default Re: type r valve train question (Dogginator)
I'm planning to rev it to 8 or 8.5 I have all the type r head stuff, the valves valve springs retainers, cams. but I'm trying to built something dependable on boost. but i dont know if i should keep the internals of the gs-r or upgrade to the type r
Old May 22, 2005 | 04:05 PM
Dogginator's Avatar
Daisy... Daisy...
If you are planning to rebuild the head, add the Type R components. If you don't need to rebuild, the only advantages that you will gain are slightly better flowing intake valves and an slightly extended rev range, but you have to rebuild the head. The ITR cam overlap may be detrimental in a boost situation.
Old May 22, 2005 | 04:46 PM
95_GSmokeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">The ITR cam overlap may be detrimental in a boost situation.</TD></TR></TABLE>
yeah, aren't smaller cams better for boost? sell the type r stuff for more boost stuff.
lazii_boi08
Dec 25, 2012 05:10 PM
sh4k3r
Feb 24, 2011 12:24 PM
IntegraGSR(-1)
Jun 1, 2005 02:21 AM
93gsrcoupe
May 2, 2004 10:58 PM
crexer
Jan 6, 2003 06:10 PM
