Type r LSD
Old Aug 17, 2003 | 08:21 PM
wireballz's Avatar
Default Type r LSD
how much does it cost to put in the bay area and what kind of tran oil does it use ???
Old Aug 17, 2003 | 09:48 PM
MaxSterling's Avatar
Default Re: Type r LSD (wireballz)
honda mtf, 1 grand not including labor
Old Aug 17, 2003 | 09:55 PM
Dan GSR's Avatar
Default Re: Type r LSD (RoyFokker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">honda mtf, 1 grand not including labor</TD></TR></TABLE>
ITR LSD doesn't cost that much....
Old Aug 17, 2003 | 10:14 PM
pem's Avatar
pem
i not sure.. check out he engine shop
Old Aug 17, 2003 | 10:59 PM
StinkyTofu's Avatar
Default Re: Type r LSD (pem)
If you get the type r lsd from the dealer brand new, i bet it will cost around 1 grand. You can find it used for around 300. Labor itself will vary depending on shop or person.
Old Aug 17, 2003 | 11:09 PM
Henry HA's Avatar
HAnda-Tech Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pem &raquo;</TD></TR><TR><TD CLASS="quote">i not sure.. check out he engine shop</TD></TR></TABLE>
If you dont know, why did you even post? It would be around 350 used. 950new
Old Aug 17, 2003 | 11:11 PM
gsxr's Avatar
Default Re: Type r LSD (B18C_DC2)
also you are going to need a few extra things if you are going to be putting it in an rs/ls/gs
Old Aug 18, 2003 | 12:00 AM
JDM2ndGen's Avatar
Default Re: Type r LSD (gsxr)
what will you need to put it into a Ls tranny?
Old Aug 18, 2003 | 01:55 AM
StinkyTofu's Avatar
Default Re: Type r LSD (JDM2ndGen)
I believe the final ring gear is different on the ls/rs/gs tranny. Thats the only thing you would need to change.
Old Aug 18, 2003 | 07:07 AM
SiR831's Avatar
Default Re: Type r LSD (StinkyTofu)
I have one installed in my 94 GSR tranny. Hit up Dan @ Rcrew racing (415) 647 2739. Tell him Barney from Marina Ca sent ya. He'll give you a good price on parts and labor. Rcrew
Old Aug 18, 2003 | 07:13 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Type r LSD (SiR831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR831 &raquo;</TD></TR><TR><TD CLASS="quote">I have one installed in my 94 GSR tranny. Hit up Dan @ Rcrew racing (415) 647 2739. Tell him Barney from Marina Ca sent ya. He'll give you a good price on parts and labor. Rcrew </TD></TR></TABLE>
Agreed! I bought my engine swap from Dan and Ken, as did several people I know. Go to http://www.rcrewracing.com His shop is a little hard to find but he can tear down a tranny and put it back together like no one's business.
Gary
Old Aug 18, 2003 | 07:55 AM
MikeTV
Guest
Posts: n/a
Default Re: Type r LSD (Gee3)
This is kind of off topic, but I used to be in the market for lsd also, but it kin dof seemed like a waste when I found that I was consistently beating type Rs off of the line (even though they caught up to me and beat me in the end). I dont know, I guess a good set of tires goes a long way.
Old Aug 18, 2003 | 08:12 AM
Rory Breaker's Avatar
Default Re: Type r LSD (Eclipse spanker)
Or the drivers of those ITR's need some work!
Its not all about straight line acceleration, especially with the ITR LSD. Just having the transfer of power by means of LSD rather than open diff causes a huge difference in the way the car feels/handles.
You can find them used for around $300 or so, and install is probably another ~$350. May as well get your clutch done while the tranny is dropped.
You should try and do Clutch/flywheel/LSD at the same time to minimize labor costs or labor headaches, depending on if you do it yourself.
chino2x2x2x
Acura TL, RL & ZDX
Jul 18, 2007 04:20 AM
TATTOO420
Mar 7, 2005 09:18 AM
7speed
Feb 17, 2005 08:17 PM
SpeedStaR3
Jul 18, 2003 04:13 PM
