type-r knock sensor
Old Apr 12, 2009 | 06:32 PM
JDM.Type-r's Avatar
Default type-r knock sensor
hey everyone, i put in a 98 jdm type-r motor into my 98 gs integra. i used my stock engine harness and noticed the knock sensor on the type-r was a single wire plug. what i did was wire on the type-r single wire plug to the stock engine harness.. now that it is running, i am getting knock sensor code...
is there something else i need to do?
could the knock sensor just not be good?
should i not have wired it this way?
any input would be of great help, thanks.
Old Apr 12, 2009 | 06:41 PM
paton5g's Avatar
Default Re: type-r knock sensor
So you have connected the knock, ran a wire through the harness and down to the ECU? You are getting the code because the ECU is not seeing it.
Old Apr 12, 2009 | 06:48 PM
JDM.Type-r's Avatar
no i used the wire from my stock harness...same colour wire on the type-r harness and my ls harness, the ls plug just had two wires(assuming the other was a ground) so i took the matching colour wire from both plugs and used that, shouldnt the computer be catching it still? unless the ecu pin setup is different between my ls and the type-r?
Old Apr 12, 2009 | 07:04 PM
JDM.Type-r's Avatar
are all obd2 ecu pin layouts identical?
Old Apr 13, 2009 | 04:39 AM
JDM.Type-r's Avatar
any help please?
bcphatchback
Dec 3, 2007 06:48 PM
rotascircuit
Aug 22, 2007 05:16 PM
crxb16ftw
May 23, 2007 09:32 PM
phanatic
May 18, 2007 02:21 PM
GR_DC2
Mar 9, 2006 12:29 PM
