Type R conversion tips
Old Jun 8, 2006 | 06:31 PM
onepoint-gsr's Avatar
Default Type R conversion tips
Just got my conversion in, was asking for some tricks and tips before I started. Anything would be helpful. Also what order would be best to put this together.
Thanks
Old Jun 8, 2006 | 06:42 PM
tomlinson619's Avatar
Default Re: Type R conversion tips (onepoint-gsr)
what conversion? lip? motor? wing?
Old Jun 8, 2006 | 06:53 PM
Desired_Speeds's Avatar
I think he means front end
Old Jun 8, 2006 | 08:27 PM
trick_db's Avatar
Default Re: (Desired_Speeds)
jdm? usdm? be specific please
Old Jun 8, 2006 | 08:58 PM
sorry about being vague...type r front end conversion. I got the radiator support,bumper support,bumper,fenders,hood,and headlights. also what wires do I tap into on the side markers so they only come on when I turn the blinker on.
Thanks
Old Jun 8, 2006 | 09:01 PM
trick_db's Avatar
before you weld your radiator support, you should try to put on the fender, hood, bumper and headlight first. and try to line it all up. see if it flush and etc. the way you want. then you can start weld. after that start wire it up this will help you out alot
http://www.masetuning.com/jdmc....html
https://honda-tech.com/zerothread?id=1346217
tkttran17
Honda Civic (2006 - 2015)
Feb 27, 2011 01:25 PM
gras
Honda Civic (2001 - 2005)
May 22, 2008 08:31 PM
WHiTETYPEs
Mar 15, 2004 10:14 AM
Revhard92si
Nov 25, 2003 02:15 PM
00ekcoupe
Apr 24, 2002 06:08 PM
