turbo?
Old Jun 11, 2003 | 10:53 PM
nio619's Avatar
Default turbo?
wut up ppl. ok i gotta 93 civic hb with a gsr motor. right now i got a intake, catback exhaust and header. the parts i have but havent installed yet r forged low comp pistons (8.5:1), forged rods, copper gasket, boost timing master by msd, wires, colder plugs, fuel pump regulator and engine management system by aem. these will all be taken to a shop to be installed dyno tuned when i make up my mind, sc or turbo. is an 8.5:1 comp low enough to run 14psi safely on this gsr motor? also the car will be daily driven and on pump gas so the boost will be set at around 4-7psi. will the b18c1 with these mods i listed be enough to protect my engine? the main reason i wanna go turbo is because i will have the ability to lower boost at any time with the turn of a ****. this means ill put a lot less stress on then engine, right? o yea will i have to worry about detonation at 14psi with all these mods? ive been to like 5 diff fourms and these r the only questions on my mind right now. thanks.
Old Jun 12, 2003 | 04:37 AM
PM-Performance's Avatar
Default Re: turbo? (nio619)
8.5:1 you wont have a prob with detonation, that is sickyl low compression .
If i may ask why'd you go that low ? Just curious.
Old Jun 12, 2003 | 04:39 AM
2k1_ITR_0736's Avatar
Default Re: turbo? (itr206)
uh, get a darton pro kit and run 28PSI make more powar!!!!!!!!
turbo is better. 28psi = like 650+ whp
Old Jun 12, 2003 | 06:05 AM
Rory Breaker's Avatar
If youre already lowering the compression, go turbo. SC's actually benefit from a bit higher compression and good tuning.
JZs15
Feb 26, 2009 03:21 PM
anthonylee29
Dec 6, 2004 03:08 PM
VTcivicEG
Jul 18, 2004 04:31 PM
nio619
Jun 11, 2003 11:16 PM
nio619
Jun 11, 2003 11:06 PM
