Trunk Leak Help
Old Apr 9, 2007 | 06:08 PM
SHG_Riley's Avatar
Default Trunk Leak Help
My friends got a 94 integra 2door, it rained 2 days ago and opened his trunk today and his trunk was filled with water. Has anyone else had the same problems or kno where its coming from and how to fix it?
Old Apr 9, 2007 | 06:40 PM
Th3savinday's Avatar
Default Re: Trunk Leak Help (r7t1g8)
check this article http://www.team-integra.net/se...D=546
most tegs have that problem...it might be coming from the opening between the tail lights and your body...you gotta search it there should be a article and pictures of it...but all you gotta do is get some silicone and fill in the gap between the taillight and the body
Old Apr 9, 2007 | 08:14 PM
Tonyl507's Avatar
Default Re: Trunk Leak Help (Th3savinday)
If it has a sunroof, you should also check the two drain hoses... They run behind the side panels, and are kinda a pain in the a$$ to get too, but i hear sometimes they disconnect themselves - draining water into your spare tire well
Old Apr 9, 2007 | 08:46 PM
Rikter's Avatar
Check your taillight seals and check the seal around the trunk as well. There may be a tear in it.
If you like working on your car(s) take apart the interior trim peices and have a friend sit in the car while someone else uses the hose on it and see where the water is comming in from and chase it from there.
-Rik
Old Apr 9, 2007 | 09:27 PM
hindsonher's Avatar
Default Re: (Rikter)
water was leaking into my teg and my friends teg too. I used black silicone to seal up the leak which was coming from the tailights.
Old Apr 10, 2007 | 08:26 AM
Tonyl507's Avatar
Default Re: (hindsonher)
can anyone post a pic of exactly where they siliconed? Do you mean in between the taillights and the body of the car?
Old Apr 10, 2007 | 08:48 AM
fergy016's Avatar
It is most likely either the 2 drain tubes from the sunroof if it has one, or the 1 drain tube from the electric antenna. Sometimes these hoses get clogged or un-plugged and they let water into the hatch area.
Old Apr 10, 2007 | 09:42 AM
Default Re: (fergy016)
not the cleanest looking but gets the job done
make sure its all around the taillight
Old Apr 10, 2007 | 10:22 AM
SHG_Riley's Avatar
Default Re: (Th3savinday)
Thanks for the input
Old Apr 11, 2007 | 05:24 AM
Tonyl507's Avatar
Default Re: (r7t1g8)
Thanks for the pics - I have tried everything from checking the sunroof drains to changing the tailight gaskets, but i still get water not only in my trunk , but IN my driver side tailight. Maybe this will help...
Old Apr 19, 2007 | 05:40 PM
994drLS's Avatar
i have the same problem and will try that
but water also makes its way to the carpet in front of the back seat so the floor is pretty much soaked. is this the same problem???
Old Jan 24, 2009 | 10:11 PM
Bad_dude's Avatar
Icon2 Re: (fergy016)
Hi,
Thanks for the pics. Could you take pics a little further out so we can see the point of reference to the light?
Thanks.
Old Jan 24, 2009 | 11:13 PM
patrick4588's Avatar
i get water in my front passenger seat floor, passenger rear floor, and trunk. it blows
b17itr
Oct 5, 2011 04:58 PM
951dc5
10
Jan 30, 2008 08:21 AM
I got a honda
Dec 15, 2007 02:03 PM
low430
May 18, 2005 10:34 PM
fiebru1119
Feb 26, 2002 03:58 PM
