trunk leak
Old Mar 2, 2010 | 10:42 AM
tech_fan23's Avatar
New User
Default trunk leak
I've got a really bad leak in my 4dr gsr. I've already re-sealed my tail lights cause a buddy of mine say thats where his was leaking at but mine is still leaking...any ideas on where it could be coming from
Old Mar 2, 2010 | 12:45 PM
SoTexDC2's Avatar
Default Re: trunk leak
It could be the hatch/trunk weather stripping, sunroof drain, spoiler gasket, or even the glass itself. Use a garden hose, spray water all around the car and check for wet spots.
Old Mar 2, 2010 | 05:37 PM
Oo0MaRkY0oO's Avatar
How did you reseal the tailights? I made new gaskets using some foam I got at the local Arts n Crafts store. If you got a sunroof, check the drain tubes to make sure they aren't clogged and they are still connected. Do the same for the antenna drain tube as well. After I did all that, I still had leaks. The last thing I saw was the pressure release vent on the drivers side. On my car, the gasket was bad so I had to make a new one with foam again. You need to remove the bumper in order to get to the vent. I haven't had any leaks after I put the new gasket on.
Old Mar 2, 2010 | 09:22 PM
1ls/vtec's Avatar
my 4 door did the same thing. Just drill a small drain hole in it to let the water drain. it helps a lot
Old Mar 2, 2010 | 11:08 PM
jDMJeRk's Avatar
You shouldn't have to do that. Fix it the right way, not the wrong way.
Tail lights are usually a good culprit as well as the weather stripping. Your best bet, like someone already suggested is to take a hose and run it around the car. All the possible leaking spots have been suggested. Give it a shot..
Old Mar 3, 2010 | 06:55 PM
Honda_ThuGZ's Avatar
ay i did the same thing LOL
Old Mar 3, 2010 | 09:18 PM
2000_IntegraGS's Avatar
I have had the same problem with my 2dr as well. I found one drain tube was disconnected from the spout on the bottom, then I found water was leaking into my tail lights then leaking through the bolt holes of the lights. I sealed the cracks along the top of the lights with some 3M weatherstrip adhesive. That worked out real well! The only problem is, I am still getting water in my trunk! Now the only spot where the water is getting in, is on the driver side by that vent. Does that really have the ability to get lots of water in whenever I wash the car or when driving in the rain??
Old Mar 3, 2010 | 09:24 PM
raneysjdmdc's Avatar
all 9 honda and acuras i've had have leaked in the trunk... i just gave up on trying to find the leaks and just drilled holes in the bottom of the trunk
blvckchrxs
Dec 26, 2012 06:04 PM
ghettoda9
Nov 3, 2011 09:53 PM
vtecdc4
Sep 21, 2010 12:43 PM
ED9man
Apr 28, 2007 11:47 PM
cdntegintx
Jun 24, 2004 07:45 PM
