trunk leak?!
Old May 9, 2009 | 09:23 PM
cristegra09's Avatar
Default trunk leak?!
jus bought and integra and it leaks but i dnt know from where...
should i jus clear *** the all around?? jus lookin for advices to fix..thanx
Old May 9, 2009 | 09:29 PM
Inaccurate's Avatar
Default Re: trunk leak?!
is the water on the passenger or driver
i had a leak around my driv
turned out the taillights werent on all the way
and my antenna o ring was bad
Old May 9, 2009 | 10:34 PM
bluestd's Avatar
could be a bad taillight gasket
Old May 10, 2009 | 07:35 AM
ok so wat u think i should do? they sell them at autozone or something or is there something at home i can use?
Old May 10, 2009 | 02:21 PM
Kerryking's Avatar
New User
Do u have a sunroof?
I have a 93 with a sunroof and its leaks through sunroof and into trunk.
Theres a tube that runs from sunroof to trunk and out the side of car thru vent that gets cloaged up or comes out of hole.
That could be it but not sure how to fix it. Just have to keep sunroof clean and every now it then blow air thru it to clean it out.
Old May 10, 2009 | 03:28 PM
Yea i gota sunroof, n i think that mite be the prob cause i waterhosed the back windshield tryna find the prob, but culdnt find no leak....ima try to find it around the sunroof..thanx
Old May 11, 2009 | 09:14 AM
nsxtasy's Avatar
H-T Order of Merit
Both the taillight assembly (the gasket, or a cracked lens, etc) and the sunroof are common causes. Check both.
Old May 11, 2009 | 10:35 AM
rufridn's Avatar
if it's the sunroof, there's two drain pipes by the rear 1/4 panels, behind your interior plastic. Those could be clogged.
It's either that or your taillight gaskets.
Old May 11, 2009 | 11:02 AM
how wuld u unclogg it u jus blow air threw it or wat?
and if it were the tail light gastkets i shuld b able to get that **** at autozone huh?
Old May 11, 2009 | 12:10 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
If you do a search there's been numerous topics about this.
Old May 11, 2009 | 12:20 PM
Sry i gota job n kids and im kinda new at this, i really dnt have the time that some of yall have to search **** up...
Old May 11, 2009 | 12:41 PM
nsxtasy's Avatar
H-T Order of Merit
So in other words, everybody else is supposed to do all the work for you, because you're not willing to do anything yourself?
dgreen78
Mar 9, 2012 03:40 AM
ghettoda9
Nov 3, 2011 09:53 PM
jweezy225
Aug 22, 2007 05:28 PM
AmauryR
Mar 22, 2007 06:01 AM
Fink2iCe
Aug 29, 2004 11:03 AM
