true or false
Old Apr 30, 2007 | 12:21 AM
jizzer671's Avatar
Default true or false
accord brakes can be used as an upgrade for the integra?
I need to know this because I need a brake job done.
thought it would be a nice simple upgrade.
if this is true what parts other than the caipers,pads, and rotors will i need?
Old Apr 30, 2007 | 01:42 AM
JDM_CRX_PLEASE's Avatar
ithink u can but im not sure about accords, but ive seen people do acura legend disc brakes w/ NSX pads. but im not sure if itll clear the stock rims or which kind of offset u need to make it not hit.
someone correct me if im wrong
Old Apr 30, 2007 | 06:11 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: true or false (jizzer671)
https://honda-tech.com/zerothread?id=734560
Use the 92-96 Prelude VTEC 282mm rotors with the 4x114.3mm pattern. You can redrill that to a 4x100mm pattern without overlapping holes. The center bore is also the correct 64mm.
Old Apr 30, 2007 | 12:34 PM
jizzer671's Avatar
Default Re: true or false (Dogginator)
Dogginator thanks for the thread. goods stuff!
TylerC161
Aug 19, 2007 03:09 PM
Stealthman80
Sep 7, 2005 08:50 PM
Boostless97Lude
Jul 19, 2003 02:56 PM
93SSPHatch
May 15, 2002 05:17 AM
greensleeper
Apr 8, 2002 01:19 PM
