Transmission replacement
Old Jan 15, 2024 | 05:52 PM
Anel27's Avatar
Default Transmission replacement
Hi, I'm from Panama and I own a 1994 Acura Integra LS equipped with an B18B3 non VTEC engine and a MP7A automatic transmission wich is presenting some problems and I'm going to replace it with a manual transmission.
Wich manual transmission (gearbox) would you recommend to?
Thanks.
Anel.
Old Jan 15, 2024 | 09:20 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Transmission replacement
Any B series Trans will work. All around good trans would be the GSR, If you like shorter gears you can go Type R, or CTR if you want a cheaper shorter gear like ITR you can go with a B16 its very similar just wont have a LSD. Tall gears go with a LS non vtec.
Old Jan 16, 2024 | 04:28 AM
Anel27's Avatar
Cool.
I'll be checking over here to find one and make the swap.
I don't mind if it has LSD or not because it's my daily drive but I'm looking for a gearbox that don't give high RPM's and poor fuel economy.
Thanks!
Old Jan 17, 2024 | 12:38 AM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by Anel27
Cool.
Thanks!
Id look for a LS trans! the 5th gear on the freeway has a low rpm and saves you gas!
Old Jan 17, 2024 | 07:15 AM
Anel27's Avatar
Ok, let's see what I find over here.
Thanks dude!
rbizzell30
Jun 9, 2008 08:36 AM
krazn
Sep 5, 2002 07:26 PM
