transmission issues
Old Jun 20, 2009 | 04:28 PM
gsr_b20b's Avatar
Default transmission issues
hey i recently bought a 2000 acura integra gsr with a b20b in it. After driving it for 2 weeks, one night i found it extremely hard to shift, so i checked the clutch fluid. It was bone dry, so i filled it up. after filling it and bleeding the lines it got a bit easier to shift but there is still a bit more effort then usual to shift. I then changed the tranny fluid for gm syncromesh and found better results, smoother shifting into all gears except 2nd. If i rev first gear past 4 grand, it is physically impossible to shift into 2nd without absolutly ramming it into gear and it is extremely hard to downshift to 2nd as well. theres no grinding it just wont go into gear. Any tips or suggestions as to what the problem is?
Old Jun 20, 2009 | 05:04 PM
ek-g6's Avatar
Default Re: transmission issues
I would guess bad syncros?
Old Jun 20, 2009 | 06:04 PM
fly_high_gsr's Avatar
well turn off u'r car and try to shif if its smooth then its something wrong with u'r pressure plate not releasing.
Old Jun 20, 2009 | 06:16 PM
MilanoCpe's Avatar
could be ur master cylinder too. my car had the same problem a week ago. it was leaking fluid then i changed it and wha la. shifts like butter!
Old Jun 20, 2009 | 07:33 PM
gsr_b20b's Avatar
yeah it shifts butterly when the car is off, and im sure its not the mastercylinder cuz the fluid has stayed the same level ever since i bled it.
Old Jun 20, 2009 | 07:36 PM
gsr_b20b's Avatar
and it shouldnt be the syncros tho, theres no grinding, only if i really really shove the shifter then it grinds into 2nd, but other then that its impossible to shift smoothly over 4,000 rpm, under that it shifts like butter
Old Jun 21, 2009 | 12:18 AM
MilanoCpe's Avatar
hm...you could also check your clutch slave cylinder for leaks or replacement.
arielb1
Dec 12, 2009 01:34 PM
NOOdS
Apr 20, 2009 11:04 AM
civiccoupe94
Nov 8, 2007 02:00 PM
aznxenon
Aug 8, 2005 02:12 PM
hb_racer
10
Mar 14, 2002 02:36 PM
