trans question
Old Jul 20, 2008 | 06:58 AM
dcwoodard's Avatar
Default trans question
will the trans case fit the gsr gearset? I have a busted gsr trans with 80k and a ls trans that I don't want to spend alot of time seeing if it is good if I could just use the case on the gsr. Let me know if you know. Also I would like to buy a gsr trans that is bad that is the only reason I haven't tried the ls yet
Old Jul 20, 2008 | 02:05 PM
vtecb18c's Avatar
Default Re: trans question (dcwoodard)
keep your eyes open in the marketplace...i've seen plenty of gsr trannys for cheap...but you can put your gsr gears in the ls if you really wanted to they are interchangable
Old Jul 20, 2008 | 07:00 PM
DiMpL3s.'s Avatar
Default Re: trans question (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">keep your eyes open in the marketplace...i've seen plenty of gsr trannys for cheap...but you can put your gsr gears in the ls if you really wanted to they are interchangable</TD></TR></TABLE>
x2
kodylive
Sep 24, 2012 04:37 PM
bball
Feb 14, 2008 11:32 PM
aaronISthrowed
Nov 22, 2006 06:07 PM
AEMintegra22
Jun 24, 2006 09:42 PM
