trans. question?
Old May 16, 2005 | 10:39 PM
Doc Nasty's Avatar
Default trans. problem question?
I just bought a 94 gsr with 195,000 miles. The tranny was fine when i test drove it and was good til i got it home. now the car wont go into any gear at all, so i put a act clutch anda fidanza flywheel in the car, a new slave, clutch master cylinder, and a fluid change with 10w40. same problem will not go into gear while the car is running. the clutch i took out had a spring that fell out of it and i figured that was the problem, but no. if the car is off it goes in to gear fine. no noise's are coming from tranny. I already seached the topic and dident get a good explaination.
would like a little help plz. Thanks.
Modified by Doc Nasty at 9:22 PM 5/17/2005
Modified by Doc Nasty at 9:24 PM 5/17/2005
Old May 17, 2005 | 06:34 AM
Doc Nasty's Avatar
Default Re: trans. question? (Doc Nasty)
bump
Old May 17, 2005 | 08:21 PM
Doc Nasty's Avatar
little help plz.
Old May 17, 2005 | 08:45 PM
Rpc07's Avatar
are you sure you put the clutch disc in correctly?
Old May 17, 2005 | 08:49 PM
Doc Nasty's Avatar
Default Re: trans. question? (Rpc07)
for the most part i had the springs and the raised hub facing out into the pressure plate. i just started to take the tranny back out. i am starting to think you cant use a stock thorw out bearing on a act clutch.
Old May 17, 2005 | 08:51 PM
Rpc07's Avatar
you should have def. replaced your throw out bearing... you didnt use the same one that was in there did you?
Old May 17, 2005 | 08:55 PM
Doc Nasty's Avatar
no i bought a new koyo bearing and pilot bearing that is why i am stumped
Old May 17, 2005 | 09:02 PM
Rpc07's Avatar
yeah that shouldnt be the problem then... are you sure the shift linkage and everything else is installed properly
Old May 17, 2005 | 09:06 PM
Dan GSR's Avatar
Default Re: trans. problem question? (Doc Nasty)
def sounds like something wasn't installed properly
Old May 17, 2005 | 09:13 PM
AK94GSR's Avatar
Default Re: trans. problem question? (Dan GSR)
yeah sumthin doesnt seem right
i had that same prob just after i bought my 94 gsr. it had the stock clutch and that
thing just fell apart and couldnt get it into any gear. once replaced it was fine
but u never know, could be a bent fork
what were u doin when it happened??
Old May 19, 2005 | 06:33 PM
Doc Nasty's Avatar
Default Re: trans. problem question? (AK94GSR)
ok i just pulled the tranny again and nothing is out of whack. the only thing i can think of is that you can not use a stock replacement throw-out bearing with a act clutch set up. the bearing is for sure contacting the pressure plate but i dont think its enough. anyone know if that is the case? let me know plz.
Old May 19, 2005 | 09:01 PM
Dan GSR's Avatar
check the part numbers
I have heard of ppl getting the wrong parts...from ACT
Old May 20, 2005 | 10:39 PM
Doc Nasty's Avatar
yeah i had the wrong throw bearing for the integra.
Dc295kid
Dec 19, 2009 07:05 AM
bonta-kun
Oct 9, 2006 11:31 AM
candy eg
Jan 23, 2006 09:56 AM
TKL
14
Nov 11, 2004 09:27 AM
AnNiMosSiTY
Nov 16, 2002 05:24 PM
