Trans problem
Old Feb 14, 2005 | 04:29 PM
CompanyFlow's Avatar
Default Trans problem
For some reason, my 3rd gear sort of "scratches" when i engage it higher than 3500 RPM, any ideas why?
Old Feb 14, 2005 | 06:40 PM
strikeback03's Avatar
Default Re: Trans problem (CompanyFlow)
synchro is wearing out. over time it will develop into a full grind. what fluid are you using, and how old is it?
Old Feb 15, 2005 | 04:07 PM
Default Re: Trans problem (strikeback03)
No idea how old it is, or what kind of fluid im using. Just started scratching Saturday night, and I only drive it on the freeway to go to school.
Old Feb 15, 2005 | 10:49 PM
HmgLauj69's Avatar
try changing your fluid....heard good stuf about GM syncros or something...i personally use honda mtf though...might get ride of the the "scratching" but wont solve the problem
Old Feb 16, 2005 | 08:07 AM
sir boostalot's Avatar
Default Re: Trans problem (HmgLauj69)
i had teh same problem with my old LS tranny bfore i got gsr tranny with clutch/flywheel. that's gonna become a full grind in a while unless you make sure you baby it into third now and keep the revs under 3k when doing so.
You should definetely get a tranny flush.
Old Feb 16, 2005 | 03:09 PM
Default Re: Trans problem (sir boostalot)
It pretty much grinds nwo going into 3rd; hows it gonna get worse?
TREESnoseeds787
Feb 11, 2007 08:55 AM
96 EX
Dec 8, 2005 06:48 AM
DMF
Jun 23, 2003 11:15 AM
PrecisionH23a
Jun 16, 2003 07:29 AM
ChingonGSR
Apr 18, 2003 11:16 AM
