Tranny Problem HELP!
Old Nov 29, 2006 | 05:19 PM
IgnitionZ05's Avatar
Default Tranny Problem HELP!
Hey, I noticed my tranny is leaking a few drops but on the other hand i kno i need a new clutch since my rpms r flying high when i step on the gas hard in 2-5th gear what could b the problem?? Tranny seal? let me kno
Old Nov 29, 2006 | 06:04 PM
JasonST's Avatar
Default Re: Tranny Problem HELP! (IgnitionZ05)
Ur rpms fly high when u floor it? That's usually what happens when u floor it and hit Vtak! If it's in gear and screaming mad high yet ur not going anywhere probly ur clutch slipping. As far as the leaking tranny fluid, check underneath the car, u should be able to see a few drops hanging somewhere, and just follow it back to the leak or crack.
Old Nov 29, 2006 | 08:25 PM
cranny's Avatar
24.224.233.247
Default Re: Tranny Problem HELP! (JasonST)
the oil your leaking could be whats causing your clutch to slip. find the leak dude , if its comming from inside the clutch housing , its most likely a rear main seal gone.
Old Nov 30, 2006 | 05:18 PM
Default Re: Tranny Problem HELP! (cranny)
thanks man ill ask my mechanic about it.
_________________________________________________
2001 Acura Integra GSR!
mawkiemarc
Aug 1, 2005 08:41 PM
reeder321
12
Dec 31, 2003 07:29 AM
J-Brooks
Dec 17, 2002 10:23 AM
phatintegra
12
Mar 20, 2002 05:37 PM
