tranny mount
Old May 6, 2005 | 11:52 AM
StrictlyJdm94's Avatar
Default tranny mount
i jst did the clutch on my 94 integra about 2 weeks ago before i did it the car wouldnt go into 3rd gear soemtimes then when i was putting the tranny back i saw that one of the bolt that are on the trannny that u bolt onto the tranny mount was off could that be a reason my car still wont go into 3rd bc when the motor moves it shifts the tranny????????????
Old May 6, 2005 | 12:07 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: tranny mount (StrictlyJdm94)
Before
"i jst did the clutch on my 94 integra about 2 weeks ago before i did it the car wouldnt go into 3rd gear soemtimes then when i was putting the tranny back i saw that one of the bolt that are on the trannny that u bolt onto the tranny mount was off could that be a reason my car still wont go into 3rd bc when the motor moves it shifts the tranny????????????"
After
I replaced the clutch on my 94 integra about 2 weeks ago. Before, the car wouldnt go into 3rd gear. When I was putting the tranny back in, I saw that one of the bolts that are on the trannny mount was off. Could that be a reason my car still wont go into 3rd gear?
Ah, much better. Anyways, I doubt it. I dont see a connection between your tranny mount and your shifting problem. If your tranny mount was loose, your engine would clunk and shift, however there wouldnt be a problem shifting gears. Especially if you can still shift into 1st, 2nd, 4th, and 5th. Most likely your sychros are screwed or some other internal tranny problem.
Take it to AAMCO, that's A-A (beep beep) M-C-O.
Old May 7, 2005 | 05:14 AM
Default Re: tranny mount (carma_626)
so i typed this really fast because i was on my way out you know what it was suppost to say you don't have to be an A**hole and correct it
ATrin
Apr 8, 2008 01:25 PM
eluder33
Dec 11, 2004 11:59 PM
NSTY Z33
Jun 24, 2004 06:45 AM
aeolus
May 22, 2002 09:31 PM
