tranny help
Old Mar 6, 2006 | 05:02 PM
DC_RaceR's Avatar
Default tranny help
Okay.. I just open my tranny and place LSD inside...
Is there any speacial way to put the housing back? I can't get it back together.
Seem like it's hitting something.
Old Mar 6, 2006 | 05:17 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: tranny help (DC_RaceR)
I heated the transmission housing to ease the entry of the differential bearing. For the shafts and shift rods, you just need to wiggle. Check that the snap ring on the counter shaft is spread as well. Make sure that part 11 on the mainshaft is aligned with the slot.
How close are you getting the cases?
Old Mar 6, 2006 | 05:20 PM
blkb18's Avatar
you may be hanging up on the c clip on the end of the shaft, remember the one under the plug that you removed with a 1/2 inch rachet or extension.
Old Mar 6, 2006 | 05:24 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">you may be hanging up on the c clip on the end of the shaft, remember the one under the plug that you removed with a 1/2 inch rachet or extension.</TD></TR></TABLE>
You're referring to the snap ring (part 12).
Most critically, test sping the input shaft for all gears before reinstalling the transmission.
Old Mar 6, 2006 | 05:27 PM
DC_RaceR's Avatar
Default Re: tranny help (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">
How close are you getting the cases?</TD></TR></TABLE>
When the Diff. Bearing just about the hit the hole.
Seem like it's hit something on top. It's not the bearing clamp Ring on top.
might be the long rod or reverse... Will try again tomorrow
blkb18's Avatar
snap ring, yes that is what i meant, it makes it easy if you have a friend open the snap ring while you wiggle the case on.
Old Mar 6, 2006 | 05:29 PM
DC_RaceR's Avatar
do the #12 ring goes on the bearing before putting on the housing?
Old Mar 6, 2006 | 05:30 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">
might be the long rod or reverse... Will try again tomorrow</TD></TR></TABLE>
I stuck my hand between the cases and wiggled the shift rods to achieve alignment. It just takes a little patience and persistence.
Old Mar 6, 2006 | 05:32 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC_RaceR &raquo;</TD></TR><TR><TD CLASS="quote">do the #12 ring goes on the bearing before putting on the housing? </TD></TR></TABLE>
You start the snap ring before the cases are totally together.
Old Mar 7, 2006 | 04:18 PM
DC_RaceR's Avatar
Could someone tell me which is which gear?
So I could understand what gear is what.
I haven't try to put on the tranny yet...
thinking about swapping b16 3rd and 4th gear in to the ls...
But don't know what gear is what because of two shaft.
odidipissuoff
Transmission & Drivetrain
Mar 16, 2010 06:45 PM
93sivtec
Nov 19, 2007 02:11 PM
spooledhonda
Oct 20, 2006 06:22 AM
Circuit Star-29
Mar 6, 2006 12:09 AM
