what trans fluid is recommended for the gsr hydro tranny? i was lookin at Amsoil .. they any good?
I believe Honda MTF is really good and so is GM Sychromesh
the owners manual recommend Honda MTF or motor oil.
my acura dealer near me gave me the mtf for free, and since the transmission was designed for that acura mtf, its worth using it
Honda or GM Syncromesh, if you drive it hard look for the GM Syncromesh Friction Modified, its good stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">Honda or GM Syncromesh, if you drive it hard look for the GM Syncromesh Friction Modified, its good stuff.</TD></TR></TABLE>
indeed it is good stuff, or so ive heard... i also heard it was like 17 bucks a quart.. anyone wanna verify this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 »</TD></TR><TR><TD CLASS="quote">
indeed it is good stuff, or so ive heard... i also heard it was like 17 bucks a quart.. anyone wanna verify this?</TD></TR></TABLE>
Depends on your area and delearships prices. My local delearship has them for 14 bucks a pop which I think is alot since you need to buy 3.
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL 74 »</TD></TR><TR><TD CLASS="quote">the owners manual recommend Honda MTF or motor oil.</TD></TR></TABLE>
Motor oil should only be used temporarily.
Do they even sell GM friction modified any more? I remember this from a few months ago.
https://honda-tech.com/zerothread?id=2184992
thanks for the replys looks like the friction modified ftw
Honda MTF...You'll only need two and half quarts I believe...According to the helms you fill up till it pours out and then tighten that bolt in...
this is very true. fill it up 2 and 1/2 quarts and it should start to pour out the top plug and its full. just tighten up that bolt and washer and your done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">
Depends on your area and delearships prices. My local delearship has them for 14 bucks a pop which I think is alot since you need to buy 3.</TD></TR></TABLE>
its only 7 bucks a bottle at your local autozone
..i use to work there...and i also recommend using syncromesh....good stuff
..i use to work there...and i also recommend using syncromesh....good stuffHonda-Tech Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da9nguyen87 »</TD></TR><TR><TD CLASS="quote">
..i use to work there...and i also recommend using syncromesh....good stuff</TD></TR></TABLE>
Yeah at my local dealership its only around 7-8 bucks for the standard synchromesh which is the same one you find at the autozone, but we are talking about the friction modified which can not be found at the local autozone and has also be discountinued at most dealerships.
..i use to work there...and i also recommend using syncromesh....good stuff</TD></TR></TABLE>Yeah at my local dealership its only around 7-8 bucks for the standard synchromesh which is the same one you find at the autozone, but we are talking about the friction modified which can not be found at the local autozone and has also be discountinued at most dealerships.
Going to put MTF tomorrow and see how it works, although my rebuild should be successful
They no longer make GM Syncromesh friction modified, but they still sell the plain synchromesh
You can also go to autozone and pick up some pennzoil synchromesh..
I've ran it in a b16 tranny, my lsd type-r tranny, and GSR tranny and it usually takes away the grinds at higher rpms..
pennzoil is also slightly cheaper than GM.
I have only one dealership left that has about 15 of the synchromesh FM left, I just bought 3, should I buy them out ?
yes you should buy its a good product and they're discontinueing it ...
pennzoil sounds like a good product .. what about amsoil?
any of you guys try this stuff?
http://royalpurple.com/manual-....html
Im using that. It's really good compared to honda mtf. Royal purple!!!
