trailing arm bushing
Old May 31, 2004 | 08:20 AM
-KangaRod-'s Avatar
Default trailing arm bushing
is part #: 52385-sk7-n02 a trailing arm bushing for an integra? I work at a dealership and I've always been under the impression that you need to order the entire arm if you need a new bushing. I've tried to contact bert-o, I just see if there was anyone else on here that maybe knew somethign about it.
Old May 31, 2004 | 10:42 AM
IMMORTAL-B18's Avatar
Default Re: trailing arm bushing (-KangaRod-)
http://www.acuautoparts.com/AC....html
Check that site out. You can just get the bushing. I heard you have to torch the old on out, but thats what I "heard". Get the new one pressed in @ a machine shop, good to go.
Old May 31, 2004 | 11:45 AM
tilt's Avatar
i believe they used to only sell the bushing with the arm, at least it was true for a certain model... i dunno, there might be more. now it can be purchased separately.
Old May 31, 2004 | 12:21 PM
Colin's Avatar
you can now buy just the bushing....although most dealerships don't even know this, and it doesn't show up on their normal screens... you have to give them the part number so they can look it up that way. Sorta wierd. A buddy of mine works at a dealer and was in the same position as you....then he got ahold of the part number (the one you listed is correct) and ordered some to be sent to his dealership.
Check out Wes's site: http://www.performanceforum.co....html
Also, if you need more info go to http://www.g2ic.com and search (site's currently down for maintenance, so I can't just link you to the pages).
Basilias
Jan 7, 2010 10:45 PM
Vitesse
Aug 1, 2006 08:12 AM
ED9man
Suspension & Brakes
Jun 12, 2006 04:26 PM
effects66
Jul 13, 2005 10:34 PM
mrtoastyjr
May 4, 2004 10:40 PM
