TPS (Throttle Position Sensor)
no, i dont know anything about it, but according to this post: https://honda-tech.com/zerothread?id=224924
i'm having the same problem. Idles low and dies out sometimes. Then returns to normal. Keeps doing it every now and then, but has been doing it a lot lately.
is there a way to adjust it? or will i have to replace it?
EDIT: my axles were dead, probably due to this problem. i just replaced them so they're fine now, but may lead to axle failure again if i do not fix the tps problem.
yea u can adjust the tps if its probably riveted in then it should be good you have to use a multimeter to see what its reading if u do a search there is a write up for it somewhere i havent messed wit a tps in a while i think closed its .5 closed and wot its 4.5 or sum ****. Also what year is your car i have a bove full of tbs and tps sensors if yours is done i could hook u up
