torque specs+missing a lug
Old Dec 22, 2003 | 02:59 PM
94B18B1Teg's Avatar
Default torque specs+missing a lug
anybody know what the lugnuts should be torqued to on a new set of 17x7's with tuner lugnuts...
The lugnuts I got from my buddy, he only gave me 15, so I got 3 on one of the back wheels. I should have a brand new set soon coming this week hopefully. Anyway, will 3 do alright on of the wheels in the back? and what is the torque specs.
Old Dec 22, 2003 | 03:18 PM
Jowee's Avatar
Default Re: torque specs+missing a lug (94B18B1Teg)
3 should be fine for the time being. 80ft lbs is what you want.
Old Dec 22, 2003 | 05:23 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: torque specs+missing a lug (ITR 98 1162)
If you still have your stock lugnuts, I would use one of those for the time being while you're awaiting the missing one.
I realize that lugnuts for stock wheels are a different shape (acorn) from those (tapered) for aftermarket wheels, so the one lugnut won't mate around the entire seating surface of the wheel, only around a circle. But it's only temporary, and I would rather have a lugnut that mated around a circle there, than no lugnut at all.
Also, until you get your matching lugnut - whether you use one stock one or a missing one - I would suggest not going over about 65 mph and not doing any aggressive cornering, burnouts, etc.
Old Dec 22, 2003 | 10:34 PM
94B18B1Teg's Avatar
Default Re: torque specs+missing a lug (nsxtasy)
well, I went about 110 last night, felt some vibration, I took a S curve at about 45-50mph, and did about 3 burn outs. And someone said torque them to 80 pounds, but I think I hit way over kill on the 80
Thanks
Old Dec 22, 2003 | 11:15 PM
NeoBlack1108's Avatar
I was torquing to about 90lbs but had problems with my brake rotors warping, now I'm doing around 110 to 120lbs of torque and the rotors have reduced their warpage, From now on if I replace the rotors I'm going to keep the torque high.
i'm running 18x7.5's
Old Dec 22, 2003 | 11:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: torque specs+missing a lug (NeoBlack1108)
Overtorquing the lug nuts like you guys are doing can cause problems that are just as serious as undertorquing them.
Stick to 80 lb-ft.
Old Dec 23, 2003 | 12:39 AM
jDMJeRk's Avatar
90 here
Old Dec 23, 2003 | 01:56 AM
SPOOLINVTEC
Guest
Posts: n/a
Default Re: (jdmjerk)
80 ft lbs no more no less you will **** up **** if there over torqued
Old Dec 29, 2003 | 10:52 PM
Default Re: (spoolinvtec)
I dont think over torque is as dangerous if you guys think. If any of you have ever taken your car to a shop like goodyear you might notice that they use their air tools for EVERYTHING, and they dont torque anything to spec.
typically places like that torque the lugs to over 250 ft-lbs on the lugs which means to get them off by hand you have to jump up and down on the wrench just to budge it. Now that is way to much as we all know but I havent heard of anyone having any problems with over-torqued lugs, its always the undertorque that causes the problem.
Old Dec 29, 2003 | 10:58 PM
gsxr's Avatar
Default Re: (NeoBlack1108)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoBlack1108 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think over torque is as dangerous if you guys think. If any of you have ever taken your car to a shop like goodyear you might notice that they use their air tools for EVERYTHING, and they dont torque anything to spec.
typically places like that torque the lugs to over 250 ft-lbs on the lugs which means to get them off by hand you have to jump up and down on the wrench just to budge it. Now that is way to much as we all know but I havent heard of anyone having any problems with over-torqued lugs, its always the undertorque that causes the problem.</TD></TR></TABLE>
have you ever seen them use this product??
http://buy1.snapon.com/catalog...talog
stick with 80ft lbs. i bet those shops that overtorque your lugs just want you to come back to get them loosened by them for an extra fee
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoBlack1108 &raquo;</TD></TR><TR><TD CLASS="quote">to get them off by hand you have to jump up and down on the wrench just to budge it. </TD></TR></TABLE>
this is how they can snap, you should not jump up and down on the wrench.
Modified by gsxr at 12:11 AM 12/30/2003
Old Dec 29, 2003 | 11:06 PM
96 Ls lnTeG's Avatar
Default Re: (gsxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr &raquo;</TD></TR><TR><TD CLASS="quote">
Never thought about that
stick with 80ft lbs. i bet those shops that overtorque your lugs just want you to come back to get them loosened by them for an extra fee </TD></TR></TABLE>
Old Dec 30, 2003 | 06:56 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoBlack1108 &raquo;</TD></TR><TR><TD CLASS="quote">I havent heard of anyone having any problems with over-torqued lugs, its always the undertorque that causes the problem.</TD></TR></TABLE>
Absolutely not true. Overtorquing can create problems that range from warped rotors to stripped threads to snapped lugnuts.
Old Dec 30, 2003 | 09:09 AM
EvilIntegrationLS's Avatar
Default Re: (nsxtasy)
yes, over and undertorquing are both a problem, but go for 80 lbs torque all day. just go and buy you a torque stick and never think twice about it.
Old Dec 30, 2003 | 10:50 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (EvilIntegrationLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilIntegrationLS &raquo;</TD></TR><TR><TD CLASS="quote">go for 80 lbs torque all day. just go and buy you a torque stick</TD></TR></TABLE>
...or use a torque wrench when tightening. Either way...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilIntegrationLS &raquo;</TD></TR><TR><TD CLASS="quote">never think twice about it.</TD></TR></TABLE>
Old Dec 30, 2003 | 11:48 AM
3 plus 1's Avatar
overtorquing will warp your rotors. Period. The places that dont use torque wrenches are too lazy and doing it incorrectly.
Old Dec 30, 2003 | 03:04 PM
Bizarre's Avatar
I torqued mine at 90. Are they supposed to be torqued at 80 or 90?
Old Dec 30, 2003 | 04:03 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Bizarre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bizarre &raquo;</TD></TR><TR><TD CLASS="quote">I torqued mine at 90. Are they supposed to be torqued at 80 or 90?</TD></TR></TABLE>
80.
Old Jan 4, 2004 | 05:20 PM
are there any changes that should be made to compensate for tuner lug nuts or larger wheels? I went with 80 w/ torque wrench on my aftermarket wheels with brand new rotors and they warped in under 3 weeks.
Old Jan 4, 2004 | 08:20 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeoBlack1108 &raquo;</TD></TR><TR><TD CLASS="quote">are there any changes that should be made to compensate for tuner lug nuts or larger wheels? I went with 80 w/ torque wrench on my aftermarket wheels with brand new rotors and they warped in under 3 weeks.</TD></TR></TABLE>
80 ft-lbs should be fine, even with tuner nuts and/or larger wheels.
I bet your rotors weren't actually warped. Read this...
NorcalLX
Apr 30, 2018 09:27 PM
newyawkballa
Mar 21, 2011 07:03 AM
michael-crxsi
34
Sep 24, 2009 01:57 PM
sutrusu
Jun 20, 2002 06:52 AM
REVolution
Dec 10, 2001 05:12 PM
