Tools needed???!??!!?!?
Old Aug 4, 2011 | 11:47 AM
Gsr-teg23's Avatar
Default Tools needed???!??!!?!?
Hey so i have to change my door lock actuator on my 97 2dr gsr i have no idea what tools i will need thing is all my tools are in storage so i only want to grab what i need ya know any help would be great thanks.
Old Aug 10, 2011 | 08:07 AM
mhax's Avatar
Default Re: Tools needed???!??!!?!?
try a ratchet, some box, some wrench, you should be fine!
Old Aug 10, 2011 | 09:48 AM
MoRBiDThOuGhTs's Avatar
and you'll need a philips screwdriver and like 4 more question marks in your title and you should be set.
Old Aug 10, 2011 | 06:20 PM
ethos0518's Avatar
Also grab a tiny flathead screwdriver or needlenose pliers...there is usually a tiny c-clip where the the rods/linkages attach.
Tiny Phillips screwdriver to get the screw holding the inside door lever cup and arm support cup before you pull the inner door off- prying the black plastic cover by the mirror off will get you more clearance pulling it off. Yank the inner door off on the bottom and work your way around and lift up after disconnecting the lock and window wiring halfway through lifting.
Old Aug 10, 2011 | 06:52 PM
el crapitan's Avatar
Also beer
Old Aug 12, 2011 | 05:26 PM
aznwilson's Avatar
have you looked at this DIY?
https://honda-tech.com/forums/acura-integra-6/diy-integra-door-handle-removal-installation-change-door-lock-2195404/
althought it's not for the door lock actuator you get an idea of the tools and how to get inside the door
Matt300ZXT
Jun 6, 2007 06:12 PM
19jetta91
Apr 21, 2007 10:50 AM
tchen415
Dec 1, 2006 09:44 PM
businessmanph
Oct 30, 2005 10:45 PM
