tire width for tegs?
Old Mar 3, 2002 | 12:36 PM
knighteg's Avatar
Default tire width for tegs?
hey everyone i have a 94 gsr, and have kosei k1 rims, right now i have 205/40/15 tired on them, i was wondering if there are n e other lighweight rims that could hold wider tires, maybe 210 or 215? would these wider tires fit in the wheel fender for my teg? rite now i have nitto 450 tires, i would a wider tire for better grip , traction, when i drag and auto cross. thx in advance
Old Mar 3, 2002 | 12:49 PM
LS_racer's Avatar
Default Re: tire width for tegs? (knighteg)
how do you like your k-1's? I'm having a set of 17" K-1's installed tomorrow. my tire width though is 205 as well. When I was searching for wheels, the only tire size that any of the online sites would let me match to any set of 17's was 205/40/17. even for wheels that were 7.5 wide instead of 7".
Old Mar 3, 2002 | 01:58 PM
au-gsr's Avatar
Default Re: tire width for tegs? (LS_racer)
if your car is lowered i can see putting 205/40/15 but i stick with 205 50 15's. if you go to 16's then the correct tire size would be 205/45/16 i really wouldn't get a much wider profile for the car than what is reccommended from the factory(tire rub issuses). if you want more traction go the suspension rought. you've got a good set of rims already, so there's no reason to spend more money on new rims just because you're not hooking up to your satisfaction. try new springs/coilovers, strut bars(top and bottom) a strut bar for the front and maybe even upgrade your sway bars f & r. your traction will improve if you go this rought.
[Modified by au-gsr, 11:00 PM 3/3/2002]
Old Mar 3, 2002 | 02:05 PM
GSRaCeRbOI's Avatar
is your suspension done yet? i would just keep the rims but dump the tires.. i had Nitto NT 450 and they sucked ...it wouldnt take much for them to loss traction, in the rain they were pretty scary, and you could do a peel out w/o even trying... try getting better tires... if there was sand or the road was wet these things were all over the place
Old Mar 3, 2002 | 07:55 PM
knighteg's Avatar
hey guys thnx for the info, i like my k1s alot, i get alot of q's about them and compliments about them, i was just wondering if a wider tire was available, but i guess i will stick with these, as for my suspension i say it would be pretty good, i have eibach groundcontrol coilovers, with tockico shocks and struts, and no sway bars, so i will be getting a rear sway bar soon, and have the stock gsr bar up front, most people like my suspension set up, not to hard not to soft, good quality ride. thx for your guys help !
Old Mar 3, 2002 | 07:58 PM
Erik_Pb_Foot's Avatar
New User
go for the oem itr rear sway bar...
back to the subject at hand.. anything wider than a 205 on that wheel (most wheels with the right offset) will rub. 18's usually have an offset designed for a 215 tire.
Old Mar 3, 2002 | 08:00 PM
Type Goch's Avatar
New User
um your tires are kinda thin. On stock wheels (15in) the thinnest id go is 50.
Old Mar 3, 2002 | 08:03 PM
knighteg's Avatar
Default Re: tire width for tegs? (Pb_Foot)
cool thx, but y the oem itr bar? y not like a neuspeed or something else? r the factory itr stuff that great? i heard neuspeed were pretty good like the 22mm were one of the best?
oh and i got nitto 450s cuz of low money flow, before i had yokohama avs tires, they were 200bux each, and really grippy(is that a word?) so when i get some more cash i will buy some of those tires. r there n e other really good tires like the avs? money will not be a problem next time, i am getting serous about auto-x and drags. give me some other brands of tires to get, thx
Old Mar 3, 2002 | 08:07 PM
garados's Avatar
The oem ITR sway bar is 21mm or is it 22mm. Anyway, it's as good if not better than the Neuspeed. Whatever you do, get a larger sway bar in the rear. The car will handle a lot better.
Old Mar 3, 2002 | 08:10 PM
knighteg's Avatar
Default Re: tire width for tegs? (garados)
thx man, how much do those bad boys cost?
Old Mar 3, 2002 | 08:11 PM
Type Goch's Avatar
New User
yok AVS arent really the racer's choice tires. Most prefer the Falken Azenis. Not only are they cheaper but they probably perform just as well if not better than the Yok's. If money isn't an issue, you can try out the Bridgestone Potenza S03's.
Old Mar 4, 2002 | 12:17 PM
au-gsr's Avatar
Default Re: tire width for tegs? (Type Goch)
go for the neuspeed. same performance at a cheaper price as a genuine itr piece
Old Mar 4, 2002 | 05:16 PM
LS_racer's Avatar
So I got my K-1's installed, drop shipped from Tirerack.com to a local shop, all in all a great process. But my K-1's didn't appear to come with a hub center piece. So I can see through the hole in the middle of the wheel to the hub, which of course is all rusted and nasty looking.
Knighteg, is this how your wheels look or did they come with some sort of cover.
I'm going to call Tirerack tomorrow and see what the deal is but I wouldn't think they should look like they do.
Other than that I'm pretty happy with them so far. I'll update after I've had a chance to really try them out.
Old Mar 4, 2002 | 07:01 PM
New User
Default Re: tire width for tegs? (au-gsr)
Do a search... not to sound like an ***, but you will hear A LOT of opinions on this subject. You've heard mine, so I won't repeat it.
Old Mar 4, 2002 | 07:08 PM
knighteg's Avatar
hey man, i bought my car used and came with the k1s my front wheels have a cover in the middle, kind of a cone shaped shiney silver metal center piece, but my to back tires dont have n e, and my friend ordered some k1s off of tirerack too, and he didnt get n e centerpieces as well, so i guess they come like that, i have tried looking for some centerpieces but had no luck. let me know if u find some centerpiece for them, thx. by they way did u get silver, white, or the anthracite color? i have the silver ones ]
peace,. later man
Old Mar 4, 2002 | 07:49 PM
LS_racer's Avatar
I got the silver ones, damn they look nice!
but that stupid center is really getting me down. if I find out anything from tirerack I'll post the info. I'm guessing I won't get too much out of them...
Old Mar 5, 2002 | 03:51 PM
LS_racer's Avatar
peace,. later man
I called Tirerack back today and talked to a new person who sold me a set of four of the hub center pieces, I should have them by the weekend and I'll try to post a pic of how they look with the center vs without. I think it was like $40 for them including shipping. I ordered my wheels off the web and it never mentions anything about the covers and I'm not sure you could even find them on their site if you looked real hard.
Oh well the things you lose when you don't talk to a real person...
Old Mar 5, 2002 | 06:01 PM
knighteg's Avatar
hey man swweeeet, yeah post up again to tell me how u like them, cuz then if they r goodl ookin i will order some too, or u can email me about it at knightbler@aol.com, thx again man!
JDM Factor
Jun 7, 2005 01:28 AM
SSS2000
Feb 21, 2004 12:07 PM
Phase2
Apr 30, 2003 05:49 PM
Mr. Vapor
Jul 1, 2002 11:23 AM
X2BOARD
Oct 7, 2001 09:34 PM
