timing off?
so i just got my head milled, and as soon as i got it back i put it on the gsr. so before i sent it off i did do the timing and everything was at tdc. so when i got it back the head was washed and i noticed the timing was off on the head. so what should i do? any help would be appreciated.
the timing was set on the head, but when i got it back from the shop it was all off. i set the cams were at tdc, but i dont know what to do. how do i time the head with the block?
There should be three marks on the cam sprockets. One at 9:00, one at 12:00, and one at 3:00. The 12:00 marks should be pointing up, and the 3:00 mark on the exhaust sprocket should line up with the 9:00 mark on the intake sprocket. Since your head has been milled, the cam timing will be retarded slightly.
To set the ignition timing, you will need a timing light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
To set the ignition timing, you will need a timing light. </TD></TR></TABLE>
i'll let you borrow my timing gun. just pay for the shipping.
so i finally turned it on today. the only thing is that the rpms would just keep climbing. they went from3k to about5k so i shut it off. there is a lot of play in the belt. i made the belt tennsioner as tight as possible, but still alot of play. what can i do?
JDMs1eeper
18
Aug 24, 2003 12:01 AM
