throttle cable question
Old Dec 1, 2004 | 02:23 PM
LS_DON4500's Avatar
Default throttle cable question
it might sound dumb but i dropped a 98 gsr motor in my 96 LS, got all hooked up but how should i run my throttle cable into the throttle body on the gsr intake, keep the cable mounted in the same place as i ran it on my ls cause looks as if i have to move it, but when i unmounted it and ran it behind the intake, it is to long and there is a lot of slack, please let me know how you have done it or what the solution is to this problem, gay aZZ gsr intakes, thanx
Old Dec 2, 2004 | 01:50 AM
yeegsr's Avatar
Default Re: throttle cable question (LS_DON4500)
well let first say...LS tb's cable runs across Intake manifold right?
look at the picture...option #2 is for stock gsr tb's and cable....you ahve to route it that way...and make a U turn to firewall...
option #1 is for type intake manifold or SKunk2 or BLOx Im...let say if you have Skunk IM you still can use option #2 but the gsr bracket the hold the tb's cable is hella hihg it might hit ur hood....so most people use option #1 for Skunk2 Im but if you do u need to buy Type R cable and bracket...
DAmnquickDA
Jul 23, 2007 06:14 PM
eg6civic1538
Jun 30, 2007 02:50 PM
1slow_ej8
Jun 7, 2007 10:04 PM
gsrboy18
Oct 11, 2005 11:52 AM
