things to upgrade on an aging integra
Old Oct 19, 2007 | 03:37 PM
intgraCA's Avatar
Default things to upgrade on an aging integra
hey i have a 94 gsr, mileage still around 70k, but its getting old. what parts are good to upgrade before they break on me?? eg which ones am i going to have to upgrade soon or later? i ask this b/c i hate having to bring it to a shop since i have no choice when it brakes (need it done fast). i'd rather research it and just upgrade at my own convenience before the parts go bad.
things i've already done: intake, header, cat, exhaust, rims/wheels, shocks, coilovers, brakes
Old Oct 19, 2007 | 03:41 PM
SWE3TDUDE's Avatar
Default Re: things to upgrade on an aging integra (intgraCA)
Wow, very low miles on a 12+ year old car. Do you just leave that baby in the garage and only take it out on weekends? lol
Old Oct 19, 2007 | 03:48 PM
intgraCA's Avatar
Default Re: things to upgrade on an aging integra (SWE3TDUDE)
used to live in the city and didn't need to drive much. but now im driving a lot more
Old Oct 19, 2007 | 04:19 PM
Blahblah718293's Avatar
your getting near the timing belt/waterpump interval, but cause of the age you may wanna do that anyway. if your real **** you could check on the radiator. but its all pretty much just basic maintenance for things that NEED to get replaced.
like intake, header, rims... those are items that just dont go bad. as long as nothings wrong wtih them.
Old Oct 19, 2007 | 04:31 PM
dc2Li's Avatar
Default Re: things to upgrade on an aging integra (Blahblah718293)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blahblah718293 &raquo;</TD></TR><TR><TD CLASS="quote">your getting near the timing belt/waterpump interval, but cause of the age you may wanna do that anyway. if your real **** you could check on the radiator. but its all pretty much just basic maintenance for things that NEED to get replaced.
like intake, header, rims... those are items that just dont go bad. as long as nothings wrong wtih them.</TD></TR></TABLE>
x2
Old Oct 19, 2007 | 04:38 PM
intgraCA's Avatar
Default Re: things to upgrade on an aging integra (dc2Li)
o ya thanks good one. things like that. i did the timing belt/water pump already to be safe. got that checked off
Old Oct 19, 2007 | 04:41 PM
intgraCA's Avatar
maybe i'll start looking into radiators. when do those usually go bad?
Old Oct 19, 2007 | 07:12 PM
dc2doi's Avatar
What I like to do is whenever I do a major tune up on a high mileage car is to check/replace coolant hose. Not just the upper and lower coolant hose, but all of the smaller ones too. Since your car is 12 years old you may want to look into it.
Old Oct 19, 2007 | 07:25 PM
Lro255's Avatar
Check for rust especially on the quarter panel, remove the weather strip.
Old Oct 20, 2007 | 08:12 PM
intgraCA's Avatar
Default Re: (Lro255)
thanks, good ideas
Old Oct 20, 2007 | 11:03 PM
Gafoto's Avatar
Check both inner and outer CV joint boots and all your fluids.
Old Oct 21, 2007 | 07:37 AM
intgraCA's Avatar
Default Re: (Gafoto)
what about those shiny things i see on the bottom of peoples car, around where the rear axles are (lca or something?). is that something im gonna need to change anyway? i don't want it unless it will actually need to be replaced later
Old Oct 21, 2007 | 08:27 AM
ChaseIntegra's Avatar
Default Re: (intgraCA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intgraCA &raquo;</TD></TR><TR><TD CLASS="quote">what about those shiny things i see on the bottom of peoples car, around where the rear axles are (lca or something?). is that something im gonna need to change anyway? i don't want it unless it will actually need to be replaced later</TD></TR></TABLE>
Yes Lower Control Arms, those aren't ever a "need" to replace item. For suspension gurus they lighten things up but mostly there for looks.
Old Oct 21, 2007 | 08:34 AM
ac_attak's Avatar
Default Re: (ChaseIntegra)
Just replace the parts as need be. You won't save any money replacing them before they actually need to be. Timing belt you replace before it snaps because if you don't, you risk an expensive engine rebuild.
Old Oct 21, 2007 | 02:12 PM
ALF's Avatar
ALF
Also check your suspension bushings.
Old Oct 21, 2007 | 04:52 PM
whatan00b's Avatar
Default Re: things to upgrade on an aging integra (ALF)
Yeah man you deffinitly want to change all those coolant hoses and while your in there get the thermostat I have a 92 with a 180k and those things have been nothing but a pain in my rear entry so change em all
White94Civic
Mar 16, 2008 06:30 PM
biglos
Honda Civic (2006 - 2015)
12
Jan 30, 2007 03:56 PM
David-D
Honda S2000
24
Aug 31, 2006 06:13 PM
Pure_Lude
Jun 5, 2005 03:38 PM
sportsa2z22
Apr 21, 2002 07:38 AM
