thermostat replacement
Old Aug 6, 2001 | 09:46 AM
thefungus's Avatar
New User
Default thermostat replacement
just recieved my 'performance' thermostat
no instructions... no nothing.
where is the thermostat located?
it doesn't seem like a complicated part,
installation should just involve a wire right?
input appreciated.
Old Aug 6, 2001 | 09:49 AM
jonsteR's Avatar
Default Re: thermostat replacement (theFungusAmongus)
A thermostat is usually at the other end of the lower radiator hose. So just follow the hose from the radiator to the engine and you'll find it. You would only have to remove 3 bolts if am not mistaken, and you can replace it.
Old Aug 6, 2001 | 10:25 AM
96IntegraLS4DR's Avatar
Stubby wrench should help. Pretty tight spaces back there
You'll lose 2/3 of your coolant.
Old Aug 6, 2001 | 11:29 AM
berkel's Avatar
Default Re: thermostat replacement (96IntegraLS4DR)
Exactly,
I watched while my mechanic installed mine. There are 3 bolts and it's a severe PITA, but not complicated. When you install the new thermostat, there are three litle "nubs" you have to line up so it doesn't leak... No wires involved.
Good luck,
FB
Old Aug 6, 2001 | 11:51 AM
thefungus's Avatar
New User
Default Re: thermostat replacement (berkel)
great! thanks for the help everyone
..off to buy some coolant!
Old Aug 6, 2001 | 12:49 PM
immortal's Avatar
Banned
i recommend using mostly water and maybe 10% coolant. it says 50/50 but if your car overheats it doesnt work as well as if it were 90/10 or 80/20. out in here in california its hot and coolant is mostly so it doesnt freeze. or use all distilled water and some water wetter and maybe a little coolant.
Old Aug 19, 2001 | 09:32 AM
70WHP LOL's Avatar
New User
Default Re: thermostat replacement (immortal)
i just read about this on a miata page...are u talking about a 160 degree thermostat? will this mod put out more power? my car is noticably slower and quieter fter the temp gauge gets up to 'normal operating temp.' any ideas?
thanks
btw my car is a 96 dx civic
Old Aug 19, 2001 | 02:49 PM
ajbones's Avatar
New User
Default Re: thermostat replacement (70WHP LOL)
Could somebody go into this a bit more? Did you drain coolant first? Did you remove lower radiator hose from thermostat housing first? How the hell did you fit your hands in there to get at the bolts? Also, are there not only two bolts? Thanks. I do not read Japaneese (Mugen directions), and sometimes the Helm's manual might as well be in Japaneese. BTW-why in the world does the Helm's manual not have a f'n index????
Old Aug 20, 2001 | 08:18 AM
Default Re: thermostat replacement (ajbones)
I'll try.....
I didn't.
Yes. I was execting coolant rushing out but it didn't until I removed the thermostat .
Stubby wrench. Even with it, you can only get the bolt to loosen 1 degrees per turn. Tedious and time consuming.
My hand was scratched to **** but it did heal after one week.
Yes if memory serves me right.
You should disconnect the electrical connector on top of the housing first to make room.
Hope this helps
Old Aug 20, 2001 | 10:49 AM
N4Speed07's Avatar
New User
wait, someone explain to me about this "performance" thermostat, my dad just bought me a new thermostat, i didn't know they could help performance, help me out, thanks.....
KhmerPride
Apr 29, 2015 05:38 PM
h0nda n00b
Apr 25, 2012 09:24 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
turbotime
Oct 11, 2005 10:08 PM
Brett-Pac
Feb 4, 2003 08:13 AM
