Testpipe for better performance?
Old Jan 9, 2002 | 06:20 PM
Racer's Avatar
Default Testpipe for better performance?
Will a testpipe increase the performance of a Normally Aspirated (Non Turbo and Non SC) integra GS-R? Or will that only works with force induction?
Orlando
Old Jan 9, 2002 | 06:24 PM
Chris's Avatar
Default Re: Testpipe for better performance? (Racer)
Yea. and polute our air too.. testpipes are for OFF ROAD USE ONLY.
get caught on the street, and BIG FINES (~$3000)
Old Jan 9, 2002 | 06:51 PM
wreckedagain's Avatar
Default Re: Testpipe for better performance? (Chris)
yeah i noticed a difference but just dont get caught, i havent dyno it yet to see the difference, but i had to because the colector on jdm header was longer than stock collector, and also tack welded stock cat heat sheild on the bottom of cat just so it looks like i have a cat, but cops could still tell because you smoke alot more and all you smell is unburnt gas.
Old Jan 10, 2002 | 04:18 AM
Racer's Avatar
Default Re: Testpipe for better performance? (wreckedagain)
I notice that you have some mods like cams, gears, etc. Would it be the same if the engine does not have any mods on it. Would it make sense to use in the local solo X or solo 1 events.
THanks
Old Jan 10, 2002 | 06:28 AM
PM-Performance's Avatar
i saw a big diff on mine . . . . more tourque, so i would say good for scca too .
it would still make power if no other mods. but i wouldnt do it without at least other mods 1st. it wont help as much until , you got header, and exhaust.
Old Jan 10, 2002 | 08:28 AM
Racer's Avatar
Default Re: Testpipe for better performance? (itr206)
I do not have a header but already have an exhaust. Did youhave any problems witht he check engine light after the testpipe? What about noise?
Old Jan 10, 2002 | 11:24 AM
a little bit louder. . . check engine will be on , but no performance issue due to that , if you got obd2
Old Jan 10, 2002 | 01:31 PM
Comtechgsr2000s's Avatar
New User
When I had my test pipe the car smelled sooooo bad I could barely breathe when I stopped at the light. Oh and I could never open my windows either. The performance on the hand was noticable. After about 5000 rpm the car pulled really hard. This was with a stock Type R muffler too. Now that I have the carsound cat and RSR exhaust the car doesn't pull as hard. At least thats what I feel, but it could be in my head. At leat my CEL light isn't on anymore, that was really annoying.
Skippy's Avatar
I saw great performance until my O2 sensors fell out!
Old Jan 10, 2002 | 02:38 PM
mattL's Avatar
Default Re: Testpipe for better performance? (Mugenblkgsr2000)
I've been debating on what to get, i thought there wasn't that much difference between a hi-flo cat and a test pipe. do you guys recomend the carsounds or random tech? thanks
Old Jan 10, 2002 | 03:01 PM
LSBlackInteg's Avatar
Default Re: Testpipe for better performance? (mattL)
I have Carsound....are they CARB legal?!!?!?
Old Jan 10, 2002 | 03:37 PM
mattL's Avatar
Default Re: Testpipe for better performance? (LSBlackInteg)
I dunno, how do you like it though? how much did you pay?
Old Jan 10, 2002 | 10:04 PM
HKxBlur's Avatar
Default Re: Testpipe for better performance? (Superchargedb18c)
omg, rofl.. what happened?
Don't listen to the guys about the legality about the missing cat, because god knows how much trouble I will get in without my posted CARB stickers.. I don't recommend running all the time with a test-pipe or open header, it smells like gas all the time.. I ran open for a good 6mos (daily driver ) and putting the sound aside, the smell and emissions seemed the same as when running with full exhaust and no cat.. I now have a Hedman 2.5" high-flow cat that I picked up for $80 new, and I would recommend that over test-pipe to anyone who asked.. If u have the ability to switch out the test-pipe for a cat before an event, then by all means, but for the 'normal' daily-driver-type guy, roll the high-flow, it's well worth it..
schumi
Jul 23, 2005 09:14 AM
Rhetoric
Sep 29, 2003 05:09 AM
RegRedTeg
Oct 2, 2002 08:33 PM
Tommy_Gunns
Dec 10, 2001 11:22 AM
tweekerz
Nov 10, 2001 01:02 PM
