test pipe or high flow cat?
Old Mar 5, 2003 | 06:43 PM
p1ccoloz's Avatar
Default test pipe or high flow cat?
how much if any improvement would a test pipe or high flow cat make? is it worth the money? Thanks
Old Mar 5, 2003 | 06:45 PM
LS-T's Avatar
New User
Default Re: test pipe or high flow cat? (p1ccoloz)
high flow cat....hp depends on setup and if the car is N/A or FI
i have it on my turbo
Old Mar 5, 2003 | 06:48 PM
TimoneX's Avatar
New User
If you already have a header & exhaust then this may make sense. You'll probably pick up a few ponies. Test pipes are better, but illegal on the street, lead to CELs, and stink. Your call.
Old Mar 5, 2003 | 06:50 PM
p1ccoloz's Avatar
Default Re: test pipe or high flow cat? (TimoneX)
yea my engine mods are, i/h/e/cam gears, yea so whats the down sides to the test pipe? Any idea where i could get a good deal on one or on a high flow?Thanks
Old Mar 5, 2003 | 06:53 PM
StyleTEG's Avatar
test pipes hardly flow any better than a quality high flow cat.
High flow cats also don't smell, don't trip a cel, and don't pollute. Go for a highflow cat, the difference is pretty minimal.
Old Mar 5, 2003 | 06:55 PM
Young_R's Avatar
i got high flow cat from Ipsracing.com from Mike M
ok. down sides of test pipe is that well its illegal and some state if you get caught fine is very high. you will get few more hps from it then cat but i dont think it is worth it if your car is daily driving.
Old Mar 5, 2003 | 07:00 PM
LS-T's Avatar
New User
Default Re: test pipe or high flow cat? (Young_R)
i got mine from MIKE also at isp...he's got good deals going on.
Old Mar 5, 2003 | 07:06 PM
black2001gsr's Avatar
Default Re: test pipe or high flow cat? (LS-T)
I got both a test pipe and cat from SMSP
Old Mar 5, 2003 | 08:01 PM
illi Adik's Avatar
Carsound from IPS, or SMSP(smsp has the bottleneck remover as an option)
Old Mar 5, 2003 | 08:17 PM
p1ccoloz's Avatar
Default Re: test pipe or high flow cat? (Jackson4Door)
so the gains are worth the cost? anyone have any dyno proof of the power improvment? if so how many around 2-3hp or so?
Old Mar 5, 2003 | 08:31 PM
StyleTEG's Avatar
I have seen a dyno of a carsound cat vs a testpipe, and there wasn't even a 2hp difference. The slight difference that there was, could have been attributed to heat difference.
I will try and see if I can dig it up.
Old Mar 5, 2003 | 08:39 PM
p1ccoloz's Avatar
Default Re: test pipe or high flow cat? (StyleTEG)
really? humm anyone know anything about the obx cat? i mean 50 bucks is a nice price. So with even the best of high flows whats the dyno'd improvement you've seen?
Old Mar 5, 2003 | 09:10 PM
StyleTEG's Avatar
Engine building is not like legos, everything works together and effects each other as a system. A high flow cat is going to make a larger difference for an engine that has cams/high compression/etc, because at that point it is a huge bottle neck, than one that has boltons only.
A highflow cat is an essential part of an exhaust system, and you are losing performance if you stick with stock.
Beyond the diameter difference (1.8 ID instead of 2.25" or bigger) the flow is terrible.
Stock NSX 242.1 cfm
Stock Type R 223.6 cfm
Stock Integra 218.3 cfm
Car Sound 2.25" 342.7 cfm
Test Pipe 2.25" 407.1 cfm
Testpipe in red, carsound cat in blue.
Huge difference eh?
Old Mar 5, 2003 | 09:16 PM
neo1z's Avatar
carsound cat makes more tq
but in general, you can just see that the do the same thing powerwise, legally with the cat, illegally with the TP. I had a test pipe and it gave me a guiltry conscience too...eek.
Old Mar 5, 2003 | 09:47 PM
Mr.Integra's Avatar
Default Re: test pipe or high flow cat? (neo1z)
HIGH FLOW CAT ON THE STREETS
please don't contribute to air pollution.. what if one day we all got lung cancer from the air we breathe? Then would you still get a testpipe?
ProudtobeANoob's Avatar
go with car sound cats
Old Mar 5, 2003 | 09:55 PM
LS-T's Avatar
New User
Default Re: test pipe or high flow cat? (Cosmo)
getting busted with no cat is priceless
[Modified by LS-T, 10:55 PM 3/5/2003]
Old Mar 6, 2003 | 05:58 AM
94TealGSR's Avatar
I personally hollowed out my cat, and I must say I'm planning on replacing it w/a high flow cat. If you are ever behind a car w/o a Cat you will know it. The smell is just unmistakable.
Old Mar 6, 2003 | 06:30 AM
StyleTEG's Avatar
Default Re: test pipe or high flow cat? (94TealGSR)
hollowing out your cat is still bad for performance, because the diameters are still all mismatched.
For example, if you have I/H/E, and a hollow cat.
Chances are you go from a 2" collector, to a 1.8" inlet on the cat, to a 2.0" outlet on the cat, to a 2.25" or bigger exhaust. All that stepping down/up is going to kill flow quality and reduce exhaust velocity and performance.
Old Mar 6, 2003 | 09:18 AM
p1ccoloz's Avatar
I think i may be getting a obx 2.5' high flow, for $50. Just in case any comments, downsides etc? Thanks
Old Mar 6, 2003 | 09:32 AM
TimoneX's Avatar
New User
The only comment I'd have is that typically OBX parts are of very low quality. Who knows maybe they make awsome cats.
ninety3lude
Mar 1, 2008 08:36 PM
recon23
Jan 8, 2008 10:37 AM
DCSportEJ1Civic
26
Jul 16, 2007 12:44 PM
808State
May 14, 2002 11:12 AM
00PurpleGSR
Apr 13, 2002 03:29 PM
