Temperature Question
Old May 12, 2003 | 07:40 PM
Gs-RAW's Avatar
Default Temperature Question
I have had two clusters, and am now on my second engine (so second thermostat and etc sensor). The damn thing keeps running so cold. Everything opperts fine but, the needle fluctuates to so cold, its as if the car was off. but when at idle back to normal.
Anyone experience this, or have any thoughts?
Old May 12, 2003 | 08:27 PM
DR3AM's Avatar
Default Re: Temperature Question (Gs-RAW)
Are you saying that the temp needle drops to the "C" when the car is moving? If so, I think it means that the thermostat is bad and it needs to be replaced. Mine used to do this as well and when I replaced my thermostat, this problem disappeared.
Old May 13, 2003 | 11:01 AM
Gs-RAW's Avatar
Default Re: Temperature Question (Gizzzer98)
Yeah but two engines, means two thermostats. Seems odd that both are bad right?
Old May 13, 2003 | 11:27 AM
JimBlake's Avatar
Did the gauge drop instantly? That would mean an electrical problem with the sensor or wiring for the gauge. The 'true' temperature can't change instantly.
Old May 13, 2003 | 08:02 PM
Gs-RAW's Avatar
Default Re: Temperature Question (JimBlake)
No, its gradually gets lower and lower. So Its not just a short. Its something but i don't know what.
Old May 14, 2003 | 03:50 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gs-RAW &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but two engines, means two thermostats. Seems odd that both are bad right?</TD></TR></TABLE>
Sure seems odd, but not impossible. What you describe sure sounds like a stuck-open thermostat.
always smooth
Nov 16, 2007 11:03 AM
TonyRomo
Nov 6, 2007 09:06 AM
Pilot05
Sep 15, 2006 03:44 PM
blackpearlv6
May 7, 2006 08:26 AM
svtec
Jan 24, 2005 05:43 AM
