teg engine swap
Old Mar 7, 2003 | 03:13 PM
bgx9ner's Avatar
Default teg engine swap
I will be getting a 94-99 integra within a few weeks, maybe even a gsr if i get enough g's. i was wondering what types of engines can i do a swap with? i'm new to this game, so i will be getting some one else to do the swap. thanks posse
Old Mar 7, 2003 | 05:10 PM
gsr-2nr's Avatar
Default Re: teg engine swap (bgx9ner)
well if u gettin a 94 or newer non vtec integra just drop in either a gsr or type r motor most commom swap for the non vtec integras
Old Mar 7, 2003 | 05:22 PM
p1ccoloz's Avatar
Default Re: teg engine swap (gsr-2nr)
Since your having someone else do the swap do a h22 turbo, which would be nearly the same price as a itr motor.
Old Mar 7, 2003 | 06:15 PM
Westrock2000's Avatar
Default Re: teg engine swap (p1ccoloz)
or just a simple B20B/Z into a non VTEC.....pretty straightforward.
Old Mar 7, 2003 | 06:19 PM
threatcon13's Avatar
New User
ummmm no. the H22 is cheap itself, but combined with all the other parts needed, pretty much the same price as an ITR swap.
Old Mar 7, 2003 | 07:39 PM
97gSrkId88's Avatar
id get a itr swap, thats the way to go
Old Mar 7, 2003 | 08:03 PM
p1ccoloz's Avatar
Default Re: teg engine swap (Threatcon13)
all depends on where you get your motor from. say a h22 you could get for $2000, motor mounts $500, turbo $2500, total 5000 nearly same as itr. that b20 does sound good, but stock that motor is pretty weak.
[Modified by p1ccoloz, 7:41 AM 3/8/2003]
speedyplumbing
10
Feb 22, 2010 06:10 PM
uses0ap
Aug 27, 2006 09:16 PM
CRX 2.0V-T
Dec 29, 2005 03:45 PM
Sir_Phobos
Dec 9, 2002 02:08 PM
